Any of you that have fitted pod filters, what did you do with the engine breather pipe?
p.s. the filters I'm looking at don't have a hole in the bottom for poking the pipe through.
Fitted pod filter?
- MadAd
Re: Fitted pod filter?
You can either cut a hole in the filter to route it through there or you can do what I did which is put a small filter on the end of the pipe.
more info here (a bit of a blast from the past!)
http://www.trx850.com/phpBB_forum/viewt ... ther#p7556
- MadAd
Had a read through the thread thanks.
Will look at poking the breather into the filters!!
