Changes through the years?
Rural Rat
Post by Rural Rat » Tue Mar 27, 2012 11:55 pm
I am interested in any changes that were made to these bikes through the few years of production. Particularly interested in Australia spec models. Mine is a '99 (Blue) and I am about to start a light resto, it does not need much work at all but I want to keep it as original as possible.
M.V.
Re: Changes through the years?
Post by M.V. » Wed Mar 28, 2012 12:39 am
I don't think there was any... Part numbers of the valves would be changed from the first model, but that's it...
May be wrong though.
Post by phuk72 » Wed Mar 28, 2012 7:35 am
Fundamentally there were no changes to the models through the years although minor variations do exist - nothing to worry about though as everything is interchangeable
Rural Rat
Post by Rural Rat » Wed Mar 28, 2012 12:56 pm
Cheers guys. I thought as much. I did have a black '96 model originally and it did all appear the same thought it worth asking.
Post by trixynut » Wed Mar 28, 2012 1:04 pm
Yep, as has been said, ignoring early Japanese import '95 models, only changes are colours.
Wombat
Forum Marsupial
Post by Wombat » Wed Mar 28, 2012 11:16 pm
One of the few minor changes was the way of mounting the rear indicators.
Early ones like mine mounted straight to the plastic whereas the later ones mounted to a small metal plate.
cal
Post by cal » Wed Mar 28, 2012 11:24 pm
Is there not some difference with Aussie lights switches being pemanantly on? :?: Think it is to do with the switchgear
Cal
Wombat
Forum Marsupial
Post by Wombat » Thu Mar 29, 2012 4:14 am
Yeah, but there is a tiny little cover on the switchgear where the on/off light switch goes on the overseas models
Post by Con Rod » Thu Mar 29, 2012 9:46 am
was there a change in the tail-piece from a one piece to a 3 peice set up?
Post by phuk72 » Thu Mar 29, 2012 9:53 am
Con Rod wrote:was there a change in the tail-piece from a one piece to a 3 peice set up?
Not that I am aware of. In my time I owned a 1995 import (one of the first ones made) and that definitely had a 3 piece rear.
Post by Mincehead » Thu Mar 29, 2012 9:58 am
There are aftermarket one piece tail sections, I actually have one a single seat version, but they do twin seat versions too.
BigAl-TC
Post by BigAl-TC » Thu Mar 29, 2012 10:02 am
Wombat wrote:One of the few minor changes was the way of mounting the rear indicators.
If that metal plate steps out approx 8mm and is offset down about the same it is most likely part of the Ventura Rack Fitting Kit. :thumbleft:
Alan.
Dav
Post by Dav » Thu Mar 29, 2012 10:16 am
Ummm...the post 96 ones didn't hemorrhage oil :D
Post by Con Rod » Thu Mar 29, 2012 10:22 am
hmm well there ya go, guess mine is after market so
Rural Rat
Post by Rural Rat » Thu Mar 29, 2012 10:30 am
Anyone had any dealings with these guys?
http://www.oemmotorparts.com/oem3.asp?M ... X%20%20850
Seems ridiculous to me that parts can be sourced and shipped from so far away at a fraction of local dealer prices. Even after my loyal customer discount. :evil:
