Work In Progress ....
- 2TWINS
A few jobs completed, but still plenty to go at!
Wheels stripped, blasted and powder coated, new bearings and seals througout.
Replacement front discs and the usual blue spot conversion.
Split in the seat box repaired and re-painted with rattle cans.
Bum pad re-covered
Scorpion end cans
R1 sidestand
New front pegs..............
Bum pad re-covered
Scorpion end cans
R1 sidestand
Re: Work In Progress ....
Looks good.
Why the R1 sidestand: whats the benefit?
Dave.
Dave.
- 2TWINS
The original was worn so the bike was leaning over too far.
The R1 stand is about 20mm longer, so that corrected the problem, simples!!
I´ve raised the ass so much it was almost felling over, old R1 stand was a really good fixtrixynut wrote:Looks good.
Dave.
Skybone
Any specific model year(s) R1, or simply any R1 sidestand will be 20mm longer than the standard TRX one?2TWINS wrote:The original was worn so the bike was leaning over too far.
Early models 98 to 02, you can pick them up pretty cheap:
http://www.ebay.co.uk/itm/YAMAHA-R1-YZF ... 5d345dbc47
Skybone
Cheers Mince!
Something else for my ever growing shopping list then!
Skybone
What a superb mod!
Bought a '99 R1 side stand (the very same one in Mince's eBay link), managed to get it fitted today, and what a revelation. It certainly feels better when putting the bike on the side stand, the standard stand kind of felt like it was going that wee bit too far, and getting it onto the paddock stand needed a 15-20mm thick piece of wood under the stand to make it that wee bit easier to get the bike onto the paddock.
The only downside so far is that the heel piece (where you hook your heel onto to get the stand down) is actually underneath the footpeg, so you have to try and hook your heel onto the stand itself and swing it down. Other than that, the stand itself could do with a light sand, and a coat of smooth hammerite/black to spruce it up a bit.
