FUNGS bike build
FUNGS bike build
Post by alextrx850 » Mon Aug 20, 2012 10:51 am
Fung has dropped his bike [previously RODs], in to me for a spruice up to the paint work...its an early model and has this interesting pipe welded to the frame[ yes, its origional]...its linked to the air box drain thats located on the rear left side.and under the idle adjuster knob....My rex is also a 1996..dosent have this ..thoughts.?
It has a low engine number of 000053
Re: FUNGS bike build
Post by Con Rod » Mon Aug 20, 2012 10:55 am
mine has this, I presume is it a breather to prevent moisture building up and rusting the frame from the inside out
my from number is 000099, so an early one. My Engine is not the original, so no number
Post by alextrx850 » Mon Aug 20, 2012 10:58 am
Con Rod wrote:mine has this, I presume is it a breather to prevent moisture building up and rusting the frame from the inside out
With air being sucked into the carbs,.?
Just checked my 96 and definitly no pipe..my first motors number was 000455...late 96 build...black frame..
Post by Mincehead » Mon Aug 20, 2012 7:29 pm
ALL the UK bikes have it as far as I know, just an oil drain from the airbox I believe.
The oil mist from the cam box breather collects at the lowest point of the airbox and the pipe connects to the airbox base only, not inboard of the airfilter. So no, the carbs do not suck air from the frame tubes as such Alex.
I`ve plugged mine, (FCR`s, no airbox) simply to stop any `extra` moisture finding it`s way into the frame tube.
Gix
Post by Gix » Mon Aug 20, 2012 10:57 pm
mines a late model uk bike and has those..as mince said
xxr55
Post by xxr55 » Mon Aug 20, 2012 11:11 pm
Maybe you guys have discovered the difference between male and female TRX's :oops: . Mine doesn't have that little pipe - must be a girl :)
Post by Jak » Mon Aug 20, 2012 11:17 pm
xxr55 wrote:Maybe you guys have discovered the difference between male and female TRX's :oops: . Mine doesn't have that little pipe - must be a girl :)
:laughing3:
Post by fung » Thu Aug 23, 2012 9:12 am
oem out on the red one.
going to cap that "little boy" pipe, and use a long drain a'la the red bike.
:rr:
rbaron25
Post by rbaron25 » Thu Aug 23, 2012 10:13 am
Is that a circumcision or a full sex change then?
I didn't see you...
Cause you didn't bloody look!
Post by fung » Sun Aug 26, 2012 11:08 am
before
after
Post by fung » Sun Aug 26, 2012 11:14 am
out with the old
in with the new
woo hoo ...
Post by fung » Sun Aug 26, 2012 11:20 am
some time later . . .
such a nice garage filler ! !
the workers . . .
till next time . . . . .
:rr:
Post by fung » Sat Sep 01, 2012 7:27 am
The build continues . . . .
So shiny . . . . .
Next is the brake lines, front guard and fairing and thats it !!
:rr:
Post by fung » Sat Sep 01, 2012 7:34 am
sorry ;) . . . and on the 'other' side :)
:rr:
Stankflapper
Post by Stankflapper » Sat Sep 01, 2012 8:02 pm
Great work boys. I love the pics :)
