Heads up to you with foam airfilters on flatslides...
Post by HansJ » Tue Sep 11, 2012 5:00 pm
Just wanted to give a heads-up, in case you have flat-slide carbs, a well-oiled foamfilter on the velocity-stacks and tight (no) clearance on the inlet valves, this is what can happen...
Engine back-fired, lit up the filter, and whoops, there i was running around in the pit, screaming for a fire-extinguisher. Ignored by everyone, but luckily, the fire stopped by itself, without causing anything else to start burning. Wipe off, start up up, and another track-day had begun:)
Once i got home, i noticed all inlet valves had minus clearances. The engine was hard to start in the cold morning, and i guess the acceleratorpump squirted a surplus of fuel into the carbs, and then when it back-fired, all hell broke loose.
If i have the time to go to the garage, i will give another heads-up this week. That one concerns those with a YZF750 swinger, rear-sets and an "active ride-style". :D
Re: Heads up to you with foam airfilters on flatslides...
Post by Killerwhale » Tue Sep 11, 2012 5:16 pm
Way ahead of you Hasse :)
bagmaker
Post by bagmaker » Tue Sep 11, 2012 11:06 pm
scary but not un-heard of.
Apparently the trick is to keep cranking and get it started, the fire then being dragged into the bits that should be alight on the inside.
I live in fear, the way mine backfires and carries on.
those who can count
and those who cannot
Post by Tarwetijger » Wed Sep 12, 2012 7:46 pm
Hmm, I've never heard of this before. Thanks for the warning Hans, especially since I have the same setup (TDMR's trumpets, foamfilter) and a trackday coming up on friday! :shock: :roll:
Post by dandywarhol » Wed Sep 12, 2012 10:08 pm
As the man said - no inlet valve clearances are the problem - not the filters/carbs
Post by HansJ » Thu Sep 13, 2012 7:03 am
dandywarhol wrote:As the man said - no inlet valve clearances are the problem - not the filters/carbs
Correct. What puzzles me is that when i restored the engine, i put in new inlet valves. These should have been the 2nd generation, presumably sturdier and not resulting in tight clearances. Will have a look at them this winter.
In any case, a small fire extinguisher is high on my purchase list. There are many other cases in. A pit, where it could be handy...
Post by dandywarhol » Thu Sep 13, 2012 9:20 am
Hans - do you remember if the part number on the valves suffixed with -01? Maybe you were sold a batch of new original valves suffixed -00
Post by HansJ » Thu Sep 13, 2012 1:30 pm
dandywarhol wrote:Hans - do you remember if the part number on the valves suffixed with -01? Maybe you were sold a batch of new original valves suffixed -00
I believe i ordered those, that's why i refer to "2nd generation". But i'll have to double-check that.
