Rear Brake hose...and my memory
roymichaeldean
Post by roymichaeldean » Mon Dec 25, 2006 3:57 pm
Merry Christmas everybody
I am refitting my rear brake hose...and I've forgotten the route.....
there are 2 ends to the brake hose...one ' bent ' end fits on top of the rear brake master cylinder....and goes down...then through the ' bridge '....( I also removed this and cleaned and sprayed silver, but this only fits one way )..then the clip which is screwed to the frame...is screwed....downwards..or upwards...mm..I removed it to clean and spray silver...and can't remember how it goes...mmm..it holds the hose....one section fits into the clip......
The hose then fits through a plastic retainer....then down to the rear brake....
I note that the hose at the rear brake cylinder needs 2 copper washers..one below and one on top, to locate the holes...for the fluid to pass through
Has anyone followed me ..so far..or is it too many beers today ??
Haynes..isn't very illustrative.....in this area
regards
Roy
roymichaeldean
success....
Post by roymichaeldean » Mon Dec 25, 2006 4:38 pm
Hello again
Just looking at Haynes again....there is a photo...6.24 which shows the clip....fitted downwards..........so that's one question answered.....and the photo...on 1.5 shows the brake hose...with the ' bent ' end...going to the rear brake master cylinder....going down....so that's 2 questions answered...so tomorrow...I shall...continue....next step..is the bleeding....Mmmmmmm...I have an automatic bleeder......so I am looking forward to the excitement
regards
Roy
http://www.oldgirls.info
Glyn
Post by Glyn » Mon Dec 25, 2006 5:05 pm
This any use?
If you need something specific let me know and I will take a picture for you.
Glyn..
http://i64.photobucket.com/albums/h198/ ... epipes.jpg
Fetch me the Fez of forgetfulness !
roymichaeldean
That's just right
Post by roymichaeldean » Mon Dec 25, 2006 5:16 pm
Hi Glyn
That's just right.......I should be alright now...I now need to make sure the holes in the hose...line up...with the outlet holes..in the rear brake...and the rear brake master cylinder...by using enough copper washers...
I thought it looked simple 3 months ago when I took it all to pieces....but..I didn't take any photos.....and just forgot.........
bye
roy
twolfe
Post by twolfe » Wed Dec 27, 2006 10:19 am
I am not quite sure what you mean by lining up the holes in the brake line with the holes in the master cyl.etc :? You just put one copper washer either side of the fitting and do it up.The copper washers are for sealing,they have nothing to do with lining up holes.The banjo bolts are smaller than the inside of the actual fitting so the fluid flows around the inside of it and the washers seal the fitting.
roymichaeldean
missing holes
Post by roymichaeldean » Wed Dec 27, 2006 2:51 pm
Hi Twolfe
But if u don't use the washers......the bolt doesn't line up...with the hose etc...so I think the brake fluid won't flow through...methinks
roy
twolfe
Post by twolfe » Thu Dec 28, 2006 12:45 am
G'day Roy, I am obviously not understanding what you mean.The washers have to be used for sealing.Are you using the original brake lines?If so, the banjo fittings are swaged onto the lines, so the holes have to line up.
Somebody else might have to step in here because I am lost as to what Roy is saying.Sorry Roy.
Terry
Post by dicky » Thu Dec 28, 2006 4:44 am
Roy,
Pay attention, there will be a test following this lesson.
This is the rear brake master cylinder drawing, but the union and banjo fittings are basically the same for every hose end.
1. is the union bolt, this is hollow through the centre of the shaft and has a hole through the shaft (seen as a black dot) between the head and the beginning of the thread.
2. is the banjo bolt attached to the end of the hose and the sealing washers (copper or aluminium). These washers are used to provide sealing of the joint and must be replaced each time the bolt is removed.
The diameter of the unthreaded part of the shaft of the union bolt is narrower than the internal diameter of the banjo bolt, this allows fluid to flow from inside the union bolt, through the hole, and into the hose attached to the banjo bolt.
There is no requirement for the holes to align.
< Q. How much do the sealing washers cost?>
roymichaeldean
Wish I was in Sydney
Post by roymichaeldean » Thu Dec 28, 2006 8:00 am
Thank u Twolfe and Dicky
For clearing the air...........what I talk about seems simple to many.........but I am a numbscull.......sometimes......and like to check and make sure, when it comes to mechanical things........ better safe than sorry
Wish I was in Sydney...Mmmm...I used to live there, once upon a time
regards
Roy
roymichaeldean
Magnificent Diagram
Post by roymichaeldean » Thu Dec 28, 2006 1:26 pm
Hello Dicky
Do u have any more diagrams for the rest of the TRX....that is so so so...explanatory...and I can understand it
regards
Roy
TRX850 full service manual
Post by dicky » Thu Dec 28, 2006 11:41 pm
Roy,
Scroll down from the main forum menu and you should find a section called Downloads. There is a link in there to the PDF file of the full TRX850 service manual.
dicky.
