Brake and Clutch Levers
Andy H
Does any other Yamaha motorcycle model's brake and clutch levers fit the TRX?, as I want to purchase a set but cannot find TRX specific levers. Other models suchas YZF 1000 R1, R6, XJR1300 and others have numerous varieties made for them, so, if anyone knows of a match-up, I will most appreciate it!!
- M.V.
Re: Brake and Clutch Levers
OTTOMH, early year model R6 levers will work, you just need an R6 clutch perch & the brake lever will bolt straight up. Early model R1 clutch perchs are the same, not sure what year until though, obviously before they moved to a radial master cylinder.
It's been covered a fair bit already, some searching should net some exact results for you.
Welcome BTW!
Welcome BTW!
Adrian9912
If you just search for "trx850 lever" on ebay you should get many many results. Mosy of them are after market or replicated new ones, but there is also a few second hand ones. Cant get much more genuine then that. I bought a /clutch lever out of the UK last week in fact.
http://www ebay.com/itm/130854313564?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
- fung
As per my bumped post re levers, Yzf600 thundercat is a fit
YAMAHA YZF600R 1994
YAMAHA TRX850 1997
YAMAHA TRX850 1999
YAMAHA YZF600R 1997
YAMAHA TRX850 1996
YAMAHA YZF600R 1995
YAMAHA YZF600R 1998
YAMAHA YZF600R 1996 CLUTCH LEVERS Part number: 3LN8391200
YAMAHA YZF1000R 2001 FRONT BRAKE LEVER Part number: 4SV8392200
YAMAHA YZF600R 1998
YAMAHA TRX850 1997
YAMAHA TRX850 1999
YAMAHA YZF600R 1997
YAMAHA YZF1000R 1998
YAMAHA YZF600R 1996
YAMAHA YZF1000R 1996
YAMAHA YZF1000R 1997
YAMAHA TRX850 1997
YAMAHA TRX850 1999
YAMAHA YZF600R 1997
YAMAHA TRX850 1996
YAMAHA YZF600R 1995
YAMAHA YZF600R 1998
YAMAHA YZF600R 1998
YAMAHA TRX850 1997
YAMAHA TRX850 1999
YAMAHA YZF600R 1997
YAMAHA YZF600R 1996
