Standard Mirror Extensions
Overlord Neil
Post by Overlord Neil » Wed Jul 15, 2015 8:04 am
My mirrors give me a great view of my elbows, are there any longer reach mirrors (from another bike?) or well known mods that can be direct mounted to give a bit more reach?
I've seen a few cafe racer style bar end mirrors but I need to do quite a bit of tight filtering so don't really want the bars to be much wider.
Silver
Re: Standard Mirror Extensions
Post by Silver » Wed Jul 15, 2015 10:34 am
You could fit some spacers between mirror mount and fairing and use longer bolts. This only gives a small amount extra. I put about 12mm in when i had a road bike.
Overlord Neil
Post by Overlord Neil » Wed Jul 15, 2015 10:42 am
Thanks Silver, I was wondering about that, I might see if Kayla could knock up some blocks if i ping a drawing over, maybe even make it into a kit if anyone else is interested?
HolerTogni
Post by HolerTogni » Wed Jul 15, 2015 12:15 pm
Hi Neil!
Mirrors from a SV 650 S/ SV 1000 S (with the edgy framework, not the round one) are fitting in the mounting 'foot' of the original mirrors.
They are a bit longer and (to me) look good on the TRX.
Recommended greetings from Munich!
TRX 850 & Racetrack-TRiXie
Overlord Neil
Post by Overlord Neil » Wed Jul 15, 2015 12:20 pm
Thanks Holer, I suspected something would fit. Have you fitted a set yourself, do you have any pics?
SDN
Post by SDN » Wed Jul 15, 2015 12:59 pm
Pattern Suzuki GSXR750 / 1000 mirrors fit and look better + give better views than originals, pattern set are cheap
Overlord Neil
Post by Overlord Neil » Mon Feb 08, 2016 11:37 am
SDN I've gone with your recommendation (eventually) will report back when installed.
domwarman
Post by domwarman » Tue May 17, 2016 12:52 pm
Hey, I'm new here. I've just become the proud owner of a 1996 TRX.
Pretty much the first thing I did with It was to sort out the mirrors, luckily I share a workshop with a chap who has a laser cutter so I made up a bunch of 6mm black perspex riser/ stand offs for my mirrors.
I'm pretty pleased with how they worked out, because they stack you can chuck in as many as you need to get around your shoulders, I ended up with 7 plus some black abs washers in between for a total length of 50mm.
Here are a couple of pictures https://drive.google.com/folderview?id= ... sp=sharing
If anyone likes the look of them I can get a bunch made pretty easily for a small fee for materials and machine time ect..
Cheers D
craybait
Post by craybait » Fri May 20, 2016 8:24 am
with a bit more plastic you could make the shape more like an aerodynamic wing like the moto gp wing so kill to birds with one stone.
Cobb from brisbane will need a set to keep his front wheel down with his extra HP
wreckage
Post by wreckage » Sun May 22, 2016 12:38 am
Hello, domwarman.
They certainly look unique and I'm definitely interested. I was on the verge of finding someone to make me some aluminium extenders but I'd like to try yours first if you decide to make some.
I'd appreciate it if you could put me down for a set!
Cheers.
domwarman
Post by domwarman » Mon May 23, 2016 9:26 pm
Hey wreckage,
I actually have a bunch spare from the first batch, I think we cut 20. I ended up only using five on a side plus the washers for the gaps. I'll check how many there are in the workshop tomorrow and let you know. Also I got some countersunk bolts in there too, looks much better now. Cheers for the interest.
D
domwarman
Post by domwarman » Tue May 24, 2016 3:59 pm
I have 8 leftover, that should Give you a rise of 3cm including the original rubber base and washers. I'm happy to send them if you'll cover the postage.
D
wreckage
Post by wreckage » Tue May 24, 2016 10:16 pm
domwarman wrote: I'm happy to send them if you'll cover the postage.
D
I've sent you a P.M., D. Thanks! :wink:
wreckage
Post by wreckage » Tue May 31, 2016 12:26 pm
Here's my idea for mirror extensions.
I was thinking just blocks of aluminium, but these days 3D printing is an option too. If anybody out there knows any contacts in Brisbane who may have the gear to price these, I'd be interested.
The angle of the TRX mirrors would make these almost horizontal, if you wanted them that way. Of course, the angle and length can be changed to whatever is optimal for the individual. Obviously, rectangular ones with straight-through bolts would also work.
Whaddaya think?
