TDM 850 stem
Tlrelli
TDM 850 stem
Hi all was wondering if a tdm 850 yoke stem was the same as the trx 850 thanks
Re: TDM 850 stem
Nope - different diameter forks
- sadmansteve
Re: TDM 850 stem
A FZR600 4JH bottom yoke and stem will fit straight into a TRX850. They have the same 41mm forks whereas the TDM850 forks are 43mm.
The 4JH stem is welded into the bottom yoke which is steel rather than the pressed in stem into the alloy bottom yoke on the TRX.
