Trailech Vapour
funnymachine
Trailech Vapour
Post by funnymachine » Wed Aug 26, 2009 9:21 pm
Hello;
I just put one of these on my TRX and the RPM reading is really really random.
I have searched the forum for the word 'vapour' and can't seem to find anything on it here?
I have seen pics with TRX with them fitted.
So, does anyone have one fitted?
Where are the clocking the RPM from?
Any help appreciated - mine is ticking over at 4,000 RPM and rising.
Thanks
Mark
TREX CHOP https://plus.google.com/photos/11370369 ... hYfRufO6Kg
Funky little road rage
Television man is crazy saying were juvenile deliquent wrecks
Oh man I don't need tv when I gotta TRX
Kayla
Re: Trailech Vapour
Post by Kayla » Thu Aug 27, 2009 6:00 am
It's a Trailtech Vapor, not 'vapour' which is maybe why search isn't showing anything ;)
Mine's wrapped around the right hand coil wire and shows an idle of around 1000rpm. Are you sure you've got the pulse thingy set correctly. If I remember right, there is a choice between 0.5, 1 and 2- set it to 1 (I think) and it should read right. You can tap into the left hand coil or off the cdi to get a more stable signal, but I'm lazy and just really needed a speedo so am not too bothered about the tacho function (which is too small to be of any real use anyway).
funnymachine
Re: Trailech Vapour
Post by funnymachine » Thu Aug 27, 2009 1:20 pm
Aha - the old you say tomato I say tomato thing...
Vapor you say.
I connected mine to the gray wire that feeds the original tach.
That didn't work too well.
So I tried the feed to the left coil.
I don't really want to wrap the wire around the HT lead, it will look crap - but I guess I ought to try to eliminate errors.
Thanks for your help
Best
Mark
