TRX chain Sprocket sets
- SDN
Any one out there know best value / performance chain and sprocket set for TRX? Had a look on E Bay range is bewildering
- Kayla
Re: TRX chain Sprocket sets
I bought a front sprocket and chain off Wemoto.com and a 40 tooth alloy sprocket from B&C Express. It came to less than £100, all in I think
- phuk72
But the most expensive c&s you can afford. Cheap sets are a false economy
- steve speed
the best but not cheap is the DID ZVM2 it has the highest tensile strength at 10370lbs,, i only use renthal sprockets
Yep good stuff but as Steve says fookin expensive:steve speed wrote:the best but not cheap is the DID ZVM2 it has the highest tensile strength at 10370lbs,, i only use renthal sprockets
http://www.mandp.co.uk/productinfo.aspx ... er3url=DID
Treat her well and she`ll outlast any other though.
