Ok, I love my TRX but ...........
WR450FGreg
Re: Ok, I love my TRX but ...........
Post by WR450FGreg » Thu Nov 24, 2011 7:03 am
Stankflapper,
I'm usually ok until I get stuck on a steep, rocky incline! LOL!
Kevtrx849,
I've got a fixed horizontal linisher here with a 150mm wide belt. Never thought of trying that. Thanks!
'98 TRX850, '08 WR450F, '91 TZ250, '79 TZ350, '76 TZ250, '80 KX125.
JW-TRX
Post by JW-TRX » Thu Nov 24, 2011 11:45 am
So I take it you won't ride with us...we stop every 200km for petrol. Stretch your legs then ;)
Post by alextrx850 » Thu Nov 24, 2011 12:16 pm
JW-TRX wrote:So I take it you won't ride with us...we stop every 200km for petrol. Stretch your legs then ;)
STOPPING...geeez theres LIONS in Africa..!! :shock:
yeah i know..but WE, get it similar with the drop bears and the bi polar Koalas..
Post by ekoja » Thu Nov 24, 2011 8:55 pm
I have a Airhawk,
http://www.airhawk.com.au/products.php? ... gory_id=28
I can, when I use it, ride between fuel stops without any discomfort.
Mine was off another model bike, so it looks a bit daggy on the seat, but they are really good.
jjmoto
Post by jjmoto » Fri Nov 25, 2011 12:08 am
Mincehead wrote:I also fing the TRX seat to be pretty comfy in all honesty but my hardened ass has been battered for years on seats that should have been referred to as rocks! :lol:
Me too, but then i have owned an FZ750, the last word in discomfort (cracking bike tho)
WR450FGreg
Post by WR450FGreg » Fri Dec 23, 2011 9:03 am
Update:
Ok, I used the linisher to sand both the TRX and WR450F seats.
It works a treat. :D
I put the cover back on the TRX seat and I can just see a few tiny lumps if I look hard, so I might take it back off, freeze the seat and sand those out by hand.
I haven't had a chance to take it for a run yet, but sitting on the bike in my workshop it definately feels more comfortable.
Great idea kevtrx849! Thanks!
Kevtrx849
Moderator
Post by Kevtrx849 » Fri Dec 23, 2011 11:15 am
No worries, sounds like you got the desired result. 8)
( HENRY FORD )
mikey
Post by mikey » Fri Dec 23, 2011 2:28 pm
[quote="alextrx850"]Im not too bothered with the comfort from the seat itself, but really want to stop slideing around and have to hug the tank with my knees to stay in place...apart from useing velcro on my arse, i use a light wipe with clean engine oil,which gives the seat a vitamin pill and my bum stays planted....
I think all the test riders are in leathers, so the seats are fine with leathers but too slippy with fabric clothing, which is probly designed to have a low friction coefficient thingy. makes me wonder if you would slide further/faster after an off with your bum coated in 10/40 :D
WR450FGreg
Post by WR450FGreg » Mon Dec 26, 2011 8:10 am
I reckon anyone who doesn't wear leather on the road needs to think about aquiring some!
I wear full leathers, even in the middle of the Aussie summer.
I like having a full coating of skin too much to risk riding without it!
I'll put up with the heat.
Thinking about it, I only really get hot when I stop anyway.
Post by fung » Mon Dec 26, 2011 8:48 am
ALEX "recently (6 months), i started using a Motul spray product specifically designed to clean your vinyl seat but not to leave any slippery residue.
works a bloody treat.
you dont slide all over the place anymore.
being a Motul item, it pays to shop around.
cant remember what it cost tho."
beats linishing your seat eh !
:rr:
WR450FGreg
Post by WR450FGreg » Tue Dec 27, 2011 8:24 am
Fung,
I only linished the foam to make the seat more comfortable for my 47 year old arse to sit on!
Update: I took it for a 2 hour (each way) ride today ..... what a difference! It was only towards the end of the second 2 hr stint that I had to move around on the seat a bit to rest my arse.
I might pull the cover off again and "tweak" the foam a little to get it spot on this week.
Post by davamb » Tue Dec 27, 2011 10:35 am
WR450FGreg wrote:.Update: I took it for a 2 hour (each way) ride today ..... what a difference! It was only towards the end of the second 2 hr stint that I had to move around on the seat a bit to rest my arse.
Greg, if you stand up on the pegs every ten minutes or so for a couple of secs you will find that you can extend that time well past 2 hours. By the time it gets uncomfortable it's too late. I usually stand up as I drop out of highway speed on entering a town.
WR450FGreg
Post by WR450FGreg » Tue Dec 27, 2011 11:51 am
Thanks Dave, never tried that before, though I do stretch my legs fairly regularly.
I usually wait until I'm aching before standing up! DOH!
WR450FGreg
Post by WR450FGreg » Wed Jan 11, 2012 11:09 pm
I took a bit more out of the seat foam trying a different method ... a wood rasp (sort of like a hell-chunky file with teeth!)
That works really well too, but you need to continually come in from different directions with little to no pressure or it starts to tear the foam in chunks.
The freezing idea is really a waste of time IMHO. It just didn't seem hard enough to make much difference. Maybe my freezer doesn't get cold enough, I don't know.
I even tried spraying some water on it the second time I tried the freezing method to help it get harder. Still not that impressive.
All good now, got a lovely comfortable seat on my TRX and I can touch the ground on my WR450F.
Happy days!
