by Killerwhale » Wed Jan 18, 2012 11:31 pm
NWS870R wrote:Perfectly within current topic methinks Drix
Yeah my stuff is done soon so...
Just SO interested in how the Matris will perform in the 03 R1 fork!
by fung » Thu Jan 19, 2012 2:02 am
NWS870R wrote:If you lift the front of the tank there is a bracket bolted to it which in turn attatches to the frame mounts. If you remove the bracket there is a rectangular plate with 2 holes in it which sits against the anti vibration rubber. If you make another plate to the same pattern but in the thickness you want to raise the tank by & refix with the original plate still intact it will raise the front of the tank when refitted. This will in turn increase the flow of air under the tank (rather than trying to force it thru little holes in the airbox!)
to save install time, did you perhaps keep a drawing of the plate with dimensions?
by phuk72 » Thu Jan 19, 2012 9:10 am
NWS870R wrote:Very little point doing this if you're running stock airbox of course
It does make a difference as it happens (but not much as you suggest). As does ripping the foam off the outside of the standard airbox.
by coxylaad » Thu Jan 19, 2012 11:24 am
I take it all this is proven on the dyno?
Is that a true reflection of the effects given that the bike is effectively in still air, and on the road you will have a 100mph wind pushing into the undertake area?
Just a thought?
by phuk72 » Thu Jan 19, 2012 3:17 pm
coxylaad wrote:I take it all this is proven on the dyno?
Just a thought?
yep - seen it with my own eyes
And most dynos (in fact all that I've seen) have an effing great big fan to mimick the ram air effect
NWS870R
by NWS870R » Thu Jan 19, 2012 4:13 pm
To echo what Phuk is saying - the dyno i use has a forced air fan to give the effect of moving airflow. I've only ever used one dyno so that results are consistant for measuring gains as they can vary hugely from one dyno to another.
by Killerwhale » Thu Jan 19, 2012 11:26 pm
NWS870R wrote:To echo what Phuk is saying - the dyno i use has a forced air fan to give the effect of moving airflow. I've only ever used one dyno so that results are consistant for measuring gains as they can vary hugely from one dyno to another.
Bike´s ready for pickup with the Matris cartridge installed....ohhh i wich it was dry and 10 degrees!!
by fung » Fri Jan 20, 2012 6:00 am
and you think you had it rough....back in my day, we lived in brown paper bag in cesspool in middle of road. . .
Sorry killer, but its 29 deg c and balmy at the moment.
So terrible . . . 10 deg c is good for you ?
Brrrr !
Fung
by alextrx850 » Fri Jan 20, 2012 9:50 am
Makes my WINKIE shrink just thinking about it while i type on the laptop outside our bribie island cabin,..a cool breese and 25 degrees...
i might wear no underpants tomorrow..
..mmmmm that jack is good.
i love OZ
by coxylaad » Fri Jan 20, 2012 11:46 am
was like an ice rink last night at mine. nearly slipped over flat on my arse walking the dog!
Roll on April.
by Killerwhale » Sat Jan 21, 2012 1:28 pm
Blizzard over here today, first snow and it´s insane!!
