yzf 750 swingarm sprocket alignment
mark850
Post by mark850 » Tue Mar 20, 2012 9:06 pm
I have already got yzf 750 forks in my trx and now going to fit swingarm as well.
Have got yzf 750 swing arm , wheel, spindel and spacers, brake Carrier and sproket and sproket Carrier.
The thing is will the chain alignment be ok? If not am i rite in thinking all i need todo is put the standard trx sprocket on backwards?
Just fort would ask :D
Re: yzf 750 swingarm sprocket alignment
Post by Mincehead » Tue Mar 20, 2012 9:15 pm
As long as you have the `dished` sprocket that`s pretty much it, the YZF wheel assembly is wider so you need to bring the sprocket back inboard by about 3mm if my memory serves me correctly. By the way SEARCH is your friend under YZF750 swingarm, it`s been covered many times on the forum. :wink:
Obviously the best way to do it is get it all bolted up and check the alignment with a good straight edge or laser sprocket aligner, then work out what you need to do to get it right:
http://www.ebay.co.uk/itm/PROFI-CAT-SE- ... 1c24f63c0f
mark850
Post by mark850 » Tue Mar 20, 2012 10:16 pm
cool thanks for that
Post by slow codger » Wed Mar 21, 2012 10:11 pm
I have the YZF750 wheel in mine with the standard swing arm, had to turn the original dished sprocket inwards. Works fine then.
