The TRX900 Project kicks off
Post by coxylaad » Wed Nov 07, 2012 8:05 pm
ignore the exausts, they were put there as a visual thing. the full system is from a tdm 900, and I dont think they fit very well - too low and when looking from the rear angled outward.
no good. I may end up going for a kayla 2 into 1 yet.
Re the seating position, I did that based on what you see on the roads today, the seat height on the new R6 is well high. my seat is still lower than my bars.
I am missing the bracing underneath, that will be sorted tonight. more pics to follow
Post by coxylaad » Wed Nov 07, 2012 10:20 pm
Did a bit more on the rear subframe tonight, made the lower support legs, I think its worked pretty damn well even if I do say so myself :)
ignore the exhausts, they are not attached anywhere and are just hanging under the bike.
I haven't welded the parts of the subframe together yet, that could be tomorrow :)
Post by coxylaad » Sun Nov 11, 2012 12:55 am
rear subframe pretty much done now. just some mounting lugs to attach to it.
now that's done I decided to see what I could do with the inner parts of the bodywork - so for the crack I chopped up the remains of the trx rear plastics, and lo and behold it fits perfectly!
worked so well I chopped the battery holder out of the TDM plastics, and thats worked pretty well too! not got any pics of that yet.
Post by coxylaad » Sun Nov 25, 2012 2:12 am
Small update:
Acquired a thunderace swingarm during the week for £25 quid. So today I pulled the old swingarm off, give that area a good clean and fitted the freshly cleaned thunderace item.
TRX wheel no longer fits so I was about to try and get hold of a thunderace rear wheel when I remembered I hung onto my TDM900 rear wheel. Good old Yamaha have been too lazy to change anything and the TDM wheel fits in there perfectly, and it runs a 160 profile tyres for the purists.
Slowly progressing, Christmas is the planned date to get the bike running.
Post by coxylaad » Sun Dec 02, 2012 12:49 am
Very small amount of progress.
I've been looking at the chain alignment issue that I have heard about on the 900 conversion.
synopsis: yes it exists.
diagnosis:
Placed a length of straight flat steel bar on the outside of the rear sprocket, clamped it down, measured the difference to where intersects with the front sprocket like so:
thats it at the back. This is it at the front:
so the back side of that steel bar represents the outside edge of the rear sprocket. To get the amount of mis- alignment I need to measure from the outside face of the front sprocket to the back face of the steel bar.
It was 7mm. I planned to make an offset front sprocket in over, but on measuring, 7mm would make the chain touch the side of the engine casing behind the front the sprocket. I only have 2mm of possible adjustment out over on the rear, so the conclusion for me is a 5mm inset front sprocket and a 2mm spaced rear sprocket, no clearance issues and an aligned chain.
To make the front sprocket I am going to bastardise two sprockets, weld them together and mill out the inside face the 5mm required. sorted.
Now all I have to do is get the sodding nut off the front!!!
By the way I am running a thunderace rear swingarm mated to a tdm900 rear wheel.
hope all this makes sense.
cal
Post by cal » Mon Dec 03, 2012 8:43 pm
two scaffolding bars a big socket and a chain, my front nut was unbelievably tight, put a bar through the wheel to the top of the swinger (wraped in cloth) and then put a scaffold pipe over the ratchet, I know your not supposed to do that but seemed to be the only way, anyway 4ft scaffolding pole and it still would not budge,went to the forum to ask advice, went back to it the next day and it was loose...?WTF? I just smiled :? :? :shock: :D..... sprocket faries you gotta love them 8) :?
Bike is coming on well coxylad the thunderace swinger looks chunky enough and goes with the R1 forks, Keep it up!!
edit; maybe it was under the swinger.. cant remember if thats a left hand thread #-o
Cal
Post by dandywarhol » Tue Dec 04, 2012 12:16 am
It's a conventional thread on the 900 - and I go with the scaffold pipe in cloth to jamb the rear wheel. The skill is to "jerk" the 4 ft scaffold pole to "crack" the threadlock. Just applying more and more pressure just ends up with things slipping and skinned knuckles. so, remember that now Ian - all it needs is a good jerk................... 8)
Kayla
Post by Kayla » Tue Dec 04, 2012 2:10 pm
Windy gun! Or buy one of these-
http://www.machinemart.co.uk/shop/produ ... ch-kit-12v
and save yourself a lot of hassle :D
Post by dandywarhol » Tue Dec 04, 2012 2:28 pm
Kayla wrote:Windy gun! Or buy one of these-
Hadn't thought of the electric version :oops:
Post by coxylaad » Wed Dec 12, 2012 10:45 pm
Kayla kindly let me try one of her awesome 2 into 1 exhaust systems to try on the project.
here it is against the stock 900 headers:
unfortunately they don't fit :( it would appear the TDM900 sump drops a bit lower at the front, the headers touch the engine where they wrap round the front bottom of the engine. bugger. gutted cos I love them!
Post by Killerwhale » Thu Dec 13, 2012 11:50 pm
That´s why i have a TRX pan on the TDX :)
Post by coxylaad » Fri Dec 14, 2012 9:21 am
interesting.
Are they both interchangable? and do the oil feeds differ when you swap the sumps? I don't want them too, I am using the 900 oil tank.
Post by Killerwhale » Fri Dec 14, 2012 5:09 pm
coxylaad wrote:interesting.
Works fine with mine, and i guess there´s where the 0,5L of extra oil in the TDM lurks :)
Post by coxylaad » Fri Dec 14, 2012 5:13 pm
excellent - TRX850 sump ordered.
now the decision has to be made whether to go 2 into 2 or 2 into 1...
answers on a post card. are there any advantages other than looks for the twin pipes.
Post by Killerwhale » Fri Dec 14, 2012 8:21 pm
coxylaad wrote:excellent - TRX850 sump ordered.
Symmetry only for me as i LOVE loud bikes! :)
