FCR install - a few questions
Re: FCR install - a few questions
Post by Killerwhale » Wed Dec 08, 2010 3:24 pm
drix wrote:I'm talking about the physical throttle's return when engine off. :wink:
These FCRs came from a bank of 4 that got split. They came with KN filters (which are poorly adapted to fit so will get new ones) cables and throttle (not sure of their origin/what they were supposed to be used on).The guy I got them from made the mods and was running them on his TRX, standard engine with a set of cans which is the same config I have. Don't think dyno time would be required although the bike is in need of a good service for the next season so might have that done properly.
I'll play with the cable setting, see if they are too tight or not, finish off the install properly and test Dandy's suggestion. :wink:
Also check that the wire ain´t split in the housing, should go easy in the cables. Maybe guck in them...or just so easy they need som luuuube.
Post by Mincehead » Wed Dec 08, 2010 8:36 pm
Sounds like they need some lubing and perhaps re-routing, mine are smooth as silk.
Also check that the twitgrip rubber is not rubbing against the alloy throttle cable housing/handlebar clamp.There should be a vinyl or P.T.F.E washer to stop it happening. :wink:
Post by dandywarhol » Thu Dec 09, 2010 12:44 am
no point in testing my suggestion if it does it with the engine off :?
NWS870R
Post by NWS870R » Thu Dec 09, 2010 1:53 am
Which is why i asked that very question :wink:
I'd fit your original throttle assembly (the one you took off) & see if the problem persists - start with the simple stuff first. If it still sticks it can only be routing of cable, worn cable (dry or frayed) or over tightening?
drix
Post by drix » Sun Jan 09, 2011 12:54 pm
Been playing around with the cable tention but still no luck. Think I might've got the routing of cables wrong but before I undo everything, can you tell me if the cables should go below or above the bar in the middle of the frame? 8-[
Kenny
Post by Kenny » Sun Jan 09, 2011 2:15 pm
Probably be better routed from the right side of the headstock
Post by Mincehead » Sun Jan 09, 2011 2:42 pm
Hmmmm, I`m nowhere near my bike but I`m sure I remember my cables are on the outside of the right hand carb, (viewed from sitting on the bike).
Yep, thought so, these 41`s are for a duke but as I thought the cables are on the right of the carb body unless you are dealing with a bank of four:
http://www.sudco.com/Media/Sudco_Ducati ... _Carbs.jpg
The image seems to show the cables between the two carb bodies does it not, these are a pair split from a bank of four, I wonder it that`s got something to do with the problem you are encountering drix, did you check the twistgrip for operating freely (without the cables attached), lubed the cables nicely?
To be honest the routing of the cables doesn`t look as though there are any tight bends from what I can see.
I`m wondering, on the paired FCR`s there is a powerful coil spring fitted behind the cable quadrant (where the cable nipples fit) to create return pressure for the cables and linkages, you can see it here shown as item 14:
http://www.sudco.com/fcrdown_diagram.html
Useful diagram that one, part descriptions and at the bottom of the page in blue text, a link to Keihin part numbers too. :wink:
Now, if your two carbs (paired) from the split bank of four has any spring tension issues or tight spots in the linkages that`ll be your problem.
drix
Post by drix » Mon Jan 10, 2011 2:48 pm
Mincehead wrote:Hmmmm, I`m nowhere near my bike but I`m sure I remember my cables are on the outside of the right hand carb, (viewed from sitting on the bike).
Hey Mince
Thanks for all the info! :wink: True that on an original pair, the throttle cables should on the right and not in the middle like mine.
Used my old twistgrip so it's fine and part #14 is on my carbs, I'll see if I can tighten it by giving it another turn maybe. The reason I think it's routing is because the return was perfect before fitting the carbs, I'll check with the guy I bought them from and how his routing was on his rex. Might look a new cables and twistgrip to solve this otherwise. Can I get some standrad stuff from the likes of M&P or should I get something Keihin specific from a distributor?
So annoying, it's the last thing that stops me from taking the bike for a spin (along with a close to flat battery)! :lol:
A
Post by Mincehead » Mon Jan 10, 2011 10:34 pm
Speak to Allens, they`ll sort you out for cables:
http://www.allensperformance.co.uk/index.html
Their phone number is at the bottom right of that link.
If you click on the PRODUCTS box in red text, then click on THROTTLES, scroll down and you`ll see one with part number:
01_0073 (FZR style, black body).
I bought one and a pair of cables for my FCR`s when I came to fit them to the bike (the cables longer than stock as my TRX is streetfightered with Renthal bars) but actually found the cables fitted the stock TRX throttle housing fine and dandy so I never used it.
Can`t remember now how much it was. #-o
Alternatively here`s another company I`ve used over the years a great deal, they will make up ANY cables, any length and style. You can buy all manner of cable nipples and fittings, just about anything `cable` related, plus they`ll make up brake lines etc in many styles and with all manner of fittings, Venhills:
http://www.venhill.co.uk/
drix
Post by drix » Tue Jan 11, 2011 3:01 pm
Thanks Mince, I'll try them out! :wink:
drix
Post by drix » Sat Jan 22, 2011 5:39 pm
Right, had a play again and no matter the routing, as soon as they are bent to the right that's it, the throttle return isn't right. Throttle return isfine when they're in a straight line though. :roll: Is it normal that on the throttle end, the length of push cable is sticking out is longer than the pull cable one?
Think I'll be better off getting a new set off cables/throttle from Allens Performance! :lol:
Post by Mincehead » Sat Jan 22, 2011 9:31 pm
I`ve found my throttle now, (the one I never used), if you want it make me a sensible offer, it`s brand new / unused :wink:
The cables would obviously need to be sourced from Allens or anyone else though.
drix
Post by drix » Sun Mar 20, 2011 6:23 pm
Hiya all
Played once more with the FCRs this week end and still have the same problem of when fitting the pull and return cables and when I bending them... I still get that slow throttle return. When the the cables are straight, they work fine and when I disconnect the return cable, it works fine, even when bent. :?
I've used some new cables (bicycle brake cables), fitted in my original throttle cable "guides/casing" (duno how it's called in English :lol: ), all properly greased and fitted etc. etc. :?
As you can imagine, it's doing my head in and was wondering how crucial the return cable is in fitting FCRs?
A
Kayla
Post by Kayla » Mon Mar 21, 2011 9:33 am
drix wrote:Hiya all
A
It's more important than in CV carbs because you can't always rely on the carb spring to close the slides. Sometimes, and it does happen, the slide can be pulled against the carb body by the vacuum from the engine and stick open- the positive return cable prevents that happening.
Post by Mincehead » Mon Mar 21, 2011 12:38 pm
+1, that`s why there IS a return cable.
