Horny
rbaron25
Re: Horny
Post by rbaron25 » Fri Apr 29, 2011 12:47 pm
Louder than 136db?
Would love to get the nautilus on but don't think its going to happen....
I didn't see you...
Cause you didn't bloody look!
TRiXy
Re: Horny
Post by TRiXy » Tue May 31, 2011 1:22 pm
We bought 4 of these (Both parent's bikes, mine and my girlfriends) and we've fitted them to all but my bike... I'm just slack...
They're VERY impressive... Yes they're a little on the bulky side, but I wouldn't let that stop you from getting one... No reason you couldn't mount it under the rear seat or something like that, doesn't have to be behind the fairing...
http://www.aerostich.com/ear-cannon-air-horn.html
Current Rides:
Re: Horny
Post by ekoja » Tue May 31, 2011 11:02 pm
1. Mounted Fiamm trumpets with cable ties onto the brackets one either side, that attaches the rear part of the fairing to the frame.
2. Mounted the compressor to the frame rail into the area under the pillion seat, again with cable ties.
3. Ran wires from the original horn wires down to the compressor.
4. Ran clear plastic hose from the compressor to a t piece which then split to each trumpet.
5. As it is on the original horn wiring I did not think a relay would be necessary.
6. Horn is loud, distinctive sound, and instant (when you consider the length of the hose from the compressor to the trumpets.
I have had this setup for almost as long as I have had the bike, which is 5 years now.
Kevtrx849
Moderator
Re: Horny
Post by Kevtrx849 » Thu Jun 09, 2011 4:23 am
Fitted the Stebel Nautilus 139db horn today, $38 delivered. :shock: Jeezus it's loud. Mee soo horny. :lol:
Fitted it using the original horn bracket but relocated upper left of the fairing. Utilised the upper left headlight bolt.
Had a Piezo fitted that i scavenged from my house alarm and while that was loud it couldn't be heard at speed. No problem with that now 8)
( HENRY FORD )
BigAl-TC
Re: Horny
Post by BigAl-TC » Thu Jun 09, 2011 9:21 am
ekoja wrote:5. As it is on the original horn wiring I did not think a relay would be necessary.
I have had twin air horns in the past and after a few months the switch started to burn and scale up. I have always used a relay since, no probs since. :soap: :D
Alan.
Corners R Us
Re: Horny
Post by Corners R Us » Sun Jun 12, 2011 9:03 am
Stebel's don't fit. I have one on the shelf in the garage as proof!
Corners
Geoperson
Re: Horny
Post by Geoperson » Sun Jun 12, 2011 9:54 am
I just fitted a Fiamm from a 90's Mercedes, easy fit ,cheap & plentiful . Nice tooter! :)
Bottom of the heap.
