Hydraulic clutch conversion.
Re: Hydraulic clutch conversion.
Post by slow codger » Tue Aug 09, 2011 9:07 pm
:D Yep I've got to sort this out, as theres no way I could get up north. Stank, unfortunately wrist got squashed when I was 12, its a bit shorter than the other one!
Post by phuk72 » Wed Aug 10, 2011 7:59 am
Stankflapper wrote:Sorry Mince, it is Aussie slang for ( Harden the fuk Up) :D :D :D
MTFU here (man the f#ck up) ;)
Post by coxylaad » Sun May 27, 2012 10:00 pm
sorrry to dig up an old thread, but would one of these:
http://www.venhill.co.uk/Controls_and_L ... INDER.html
mate up to a standard yamaha clutch lever/master cylinder like something off an XJR1300 or something?
like this: http://www.ebay.co.uk/itm/LOOK-GENUINE- ... 2ebe57460a
then you get the hydraulic clutch which is all but standard. I have to say I love the feel of a hydraulic clutch. cables just feel cheap.
arrivisto
Post by arrivisto » Wed Jun 06, 2012 4:19 pm
Of course, instead of messing about with the clutch mechanism, you can simply do clutchless changes (all the ups and most of the downs). It may seem counter-intuitive, but clutchless changing is usually kinder to the machinery. (Of course, you must use the clutch from a standing start). Virtually all motocross and enduro riders change clutchlessly, although the practice seems less popular with road bikers.
k0no
Post by k0no » Thu Jun 07, 2012 4:23 pm
any word on the "easy clutch" mechanism thing?
i'm ok with the clutch at the moment (found a sweet spot on the normal adjustment that brings down the bite point and makes it easier to use and more progressive, which i like)
but i can imagine on longer journeys, your hand can get the CLAW occasionally from a stiff clutch.
has anyone actually used one of these easy-clutch thingamujigs? they look legit, if perhaps a little clunky.
Gix
Post by Gix » Thu Jun 07, 2012 6:52 pm
k0no wrote:any word on the "easy clutch" mechanism thing?
I have used them on mx and supermoto bikes...
on a two stroke 250 they are great and work really well but the clutch on those are usually pretty light and the easy clutch just helps with the amount of use the clutch gets
I found on a 450/500 4 stroke supermoto they did not make a huge amount of difference but the pull is lighter.
You can get levers that have several cable positions, which does the same thing
