Cafe racer rebuild and restoration.
knumbnutz
Re: Cafe racer rebuild and restoration.
Post by knumbnutz » Sat Oct 24, 2015 12:01 pm
Pictures showed that we lived
knumbnutz
Post by knumbnutz » Sat Oct 24, 2015 12:03 pm
knumbnutz
Post by knumbnutz » Sat Oct 24, 2015 12:04 pm
knumbnutz
Post by knumbnutz » Sat Oct 24, 2015 12:06 pm
Post by Mincehead » Sat Oct 24, 2015 7:42 pm
Mate, don`t take this the wrong way but, you need to practice your welding more. :wink:
knumbnutz
Post by knumbnutz » Sat Oct 24, 2015 11:11 pm
I blame it on the tools.
Using a friends MIG as the tig is broken.
They'll clean and the pictures make em look a lot worse than in reality.
knumbnutz
Post by knumbnutz » Thu Jan 14, 2016 2:19 pm
Howdy.
Over Christmas break I have been concentrating on making the triple clamps for the build.
Had to wait for various tooling to turn up, but once I got the rotary table, boring head and slitting cutter I was able to make a start.
Time for black anodising
Post by cobbadiggabuddyblooo » Thu Jan 14, 2016 3:21 pm
Looks good Neil , its all slowly coming together. 8) compromise isn't in the vocabulary :lol: :lol:
Post by alextrx850 » Thu Jan 14, 2016 10:04 pm
Nice work
Very nice
knumbnutz
Post by knumbnutz » Thu Jan 14, 2016 10:49 pm
Slowly is right. I got the shock back but he still left the reservoir in the wrong place. So I am going to have to send it back to Adelaide again. FFS.
Hard to go fast when you're waiting for 3months for a 2 minute job
petetrx
Post by petetrx » Fri Jan 15, 2016 9:39 pm
Hi knumbnutz, I see you going together the clamps anodised. Are you getting it done locally? I want to get a set of r1 forks anodised black.
knumbnutz
Post by knumbnutz » Sat Jan 16, 2016 11:28 am
Yes, there's a place at ormeau on blanck St.
Used them before. Good, well priced.
knumbnutz
Post by knumbnutz » Sat Feb 06, 2016 9:56 am
Front end on, rear shock fully mounted. Had to shape down a 60x60x80mm block of aluminium for the top shock mount and just used 12mm plate underneath.
Works a treat.
Triple clamps came up beautiful after anodising. Happy with that.
knumbnutz
Post by knumbnutz » Sun Feb 07, 2016 10:23 pm
making the shock mount 60mm x 60mm x 100mm billet takes a while to machine down.
knumbnutz
Post by knumbnutz » Sun Feb 07, 2016 10:32 pm
Shock mount at the linkage. Its the same geometry as the Triumph.
Looks about right now, bit taller
Just got to cut off the old radiator mounts and then reweld in place and then the frame is done and can be painted.
