Quickshifter-what a whole lotta fun!
Post by Killerwhale » Sun Sep 14, 2014 7:26 pm
Stu99
Re: Quickshifter-what a whole lotta fun!
Post by Stu99 » Sun Sep 14, 2014 9:40 pm
Very nice KW, indeed it does look like a lot of fun. :thumbup:
Dav
Post by Dav » Mon Sep 15, 2014 9:29 am
Thanks for the ride-along...good fun....congrats of getting it set up. That rattle at say 1:07...is that your flatslides? They are very rattley :shock:
Inspired me to do a lot of clutch-less upshifts today, lucky not to get booked! :lol:
Post by Killerwhale » Mon Sep 15, 2014 10:59 am
Dav wrote:That rattle at say 1:07...is that your flatslides?
Quite surprised what the go pro picked up myself, never heard it before. But after i changed my TPS for the TCIP4 the bike is quite different with much less engine brake. Maybe back pressure against the slides??
Goes like a mofo though :) Will do the bigger valves and new rings ASAP as well...
Edit: Thinking of it, i think it´s the 900 engine´s vibrations. It vibrates more than the trix engine.
This was done with DB killer so i´ll chuck that out and i´ll hear less of it! :)
Post by Tarwetijger » Mon Sep 15, 2014 12:31 pm
What brand / type quickshifter do you have?
I want to look into this too.
Last trackday I saw a QS from Starlane, power shift NRG, that looked promising.
Post by Killerwhale » Mon Sep 15, 2014 1:10 pm
Tarwetijger wrote:What brand / type quickshifter do you have?
It´s a cordona GP switch, you can see it in the for sale thread on TCIP4.
It was used when bought 3-4 years ago and it´s noticeble, but got it for 2 tenners so....
Post by Tarwetijger » Mon Sep 15, 2014 2:50 pm
Don't lie to us! [-X
http://www.trx850.com/phpBB_forum/viewt ... 641#p78248
4 tenners.
:lol:
Post by Killerwhale » Mon Sep 15, 2014 3:25 pm
4 tenners.
:lol:
Luckily someone has the memory intact! :)
danno
Post by danno » Mon Sep 15, 2014 9:13 pm
Please excuse my lack of knowledge on this, but is the NRG a QS that works on the TRX?
Post by Tarwetijger » Mon Sep 15, 2014 9:24 pm
Not sure but I suppose so. They state it is universal. Although it will only cut ignition, not the fueling of course like on injected bikes. I really like the solution for the sensor they use.
http://www.starlane.com/vedit/15/cronom ... dprod=1075
But Cobba reminded me I have an Ignitech unit and a QS can be added as a little extra, and it is a lot cheaper than the Starlane, I've seen them for €350. :shock: A disadvantage is that I will have to choose between push or pull, the starlane is multipurpose.
I think you know that I found this coincidentally while searching the forum for more QS info. :oops:
Post by Killerwhale » Tue Sep 16, 2014 1:14 pm
As long it´s a mechanical switch and you have the TCIP4 youre set!
Post by Tarwetijger » Tue Sep 16, 2014 7:54 pm
Killerwhale wrote:As long it´s a mechanical switch and you have the TCIP4 youre set!
Yes but you will have to choose between push or pull, right?
I don't use reversed shifting right now but for track use i might want to try it.
Post by Killerwhale » Wed Sep 17, 2014 7:46 am
Same o same ol, you can switch the old trx pin for downshift....i have done it since 2006 or so....
Same downshift now with QS!
danno
Post by danno » Thu Sep 18, 2014 10:43 pm
Whats a TCIP4?
M.V.
Post by M.V. » Fri Sep 19, 2014 12:07 am
Damn you KW, I didn't think I needed a Quickshifter on the TRX, now I think I want one! :D
Less than 60 Euro for the Ignitech ones, not a bad price at all...
