TDMR40 question
TDMR40 question
I've just picked up a pair of Mikuni TDM40 carbs stamped TDMR 40D6 T731.
The parts manual shows a linkage for accelerator pumps (part numbers 93/94) but there is no link and bellcrank on mine. What do others have on their TDMRs?
http://www.allensperformance.co.uk/images/exp-tdmr.gif
Re: TDMR40 question
Think I'll answer my own question. The carbs were built from a bank of 4 for a ZZR1000. Only one of the carbs has the pumper and feeds the others by pipework.
Someone has a pair of carbs with a pumper and I've the other pair.
Has anyone used a set of TDMR40s without an accelerator pump? I'd be interested to know before \I send them back to Germany under Ebay misrepresentation rules
Cheers, Alan
Cheers, Alan
- Tarwetijger
Re: TDMR40 question
I am using TDMRs with acc pump, yes. But I doubt if it will do worse without them.
All they do is just squirt a load of petrol in, getting the mixture too rich for a short moment.
Re: TDMR40 question
Thanks Mr T. I was wondering if there would be a big flat spot under acceleration? I've dealt with auto engines where the accelerator pump has been faulty and the car has been a pig to drive through the "hole" in the fuelling.
The seller is willing to take them back - think I'll do it - unless anyone has used TDMRs without the pumper...........................................
- M.V.
Re: TDMR40 question
Tried to set up a set of flatslides on a friends bike from a two stroke (no accelerator pump), don't do it.
Re: TDMR40 question
Thanks MV. Out of interest, what 2 stroke had pumps?
I once had a racing RD200 with 32mm Amals which had powerjets fitted but they weren't mechanical pumps, they relied on vacuum to add the extra fuel at full throttle
- M.V.
Re: TDMR40 question
Not sure, but these were jetted way too big stock, so I assume the two strokes are much richer but don't use a power jet, probably because they are usually at full throttle or off (or should be I guess!)
Even jetting them back to normal ish we still couldn't get consistent results with partial & quick WOT.
Re: TDMR40 question
When my FCR41's had an accelerator pump fault (no fuel pumping) the motor ran dreadfully. The pump is there for a reason and it will be a pig to ride without it in my opinion.
Re: TDMR40 question
Thanks for all your replies - I've sent the carbs back to Germany. Still looking around for a pair.................
- brockzila
Re: TDMR40 question
So if you got hold.of a.full bank of four carbs it would be possible to make a set of carbs for a trx with a 40mms bores?
Try a zzr forum. That motor.has an issue with spinning main bearings so there will.be a.few sets of carbc with out motors around.
Is it Brock friendly???
Re: TDMR40 question
Yep, been looking down that route ☺
