idl1975 wrote:Just a quick question - I have used the search function and not found anything precisely on point:
I recall having heard or read somewhere many years ago about using YZF 750 'dogbones' to increase ride height at the back. Can anyone fill me in as to whether this is do-able, whether any YZF-750 year will do, and whether any other mods to the linkage or rear suspension are needed?
If not, are there any companies doing different length dogbones commercially, or any other way to solve the ground clearance/slow steering issues without buying a ride-height adjustable shock? I saw the thread with the way-cool adjustable dogbones, but making those would be outside of my mechanical abilities.
Thanks to anyone who can assist!
I have a set of the YZF750 dogbones coded 4BH that are 172mm centre to centre. ( standard TRX coded 4FM-10, 182mm centre to centre) Took them off as they added way too much rear ride height.. from memory 35plus mm. I have now fitted the Metisse dogbones part # 110035 that are I think about 176mm C to C. Tail rise now about 25mm.
My bike has a 120/70 rather than the stock 120/60 and with the forks at their standard pull through in the clamps, 18.5mm from top of the clip on mount to top of the fork tube excluding fork cap. This means that the tyre gives a ride height gain at the front of approx 10mm, combined with the 25mm in the rear gives an overall attitude change of plus 15mm at the rear. The steering feels pretty sharp with this setup, just feeling a touch unstable at really high speeds and ground clearance is not a problem.
The downside is by raising the ride height at both ends I have raised the C of G and the bike pitches and dives a fair bit more. Next on the agenda is a set of dogbones 178mm C to C to give me 15mm rear rise, then I can slip the forks up in the clamps by 10mm, keep the quicker steering geometry but lower the ride height 10mm overall and regain some stability.
Two things to be aware of. Changing the dogbones changes the swingarm angle. The owners manual recommends setting the chain slack @ 20-30mm with the bike held upright . If you do this with the YZF dogbones then the chain have no slack at all when the suspension compresses under load causing serious grief to the chain and countershaft bearings..... Get round this when you have the suspension bolts out changing the dogbones by jacking the rear wheel up so the countershaft , swingarm axle and rear axle are in line. This is the point of maximum chain extension, set the chain slack for 5mm, and when you put in the suspension bolts in and let it rest on the wheels, measure the slack like in the manual and it will read something like 45mm. Mark your measure point and slack reading on the swingarm for easy adjustments in the future ( after the beer has dulled your memory)
Secondly changing the ride height to fix ground clearance issues with the stock suspension is a waste of time. If you weigh like a standard issue westener then the spring rates ( especially the front) are too soft and will blow through the travel under load - que scraping at the apex- and squat under power on the way out, the most common reason for folks wanting more rear ride hight. Get get correctly specced springs front and rear and your shock rebuilt first or you will be chasing shadows.
Cheers DFH
