Diversion XJ6 wheels
- Racer-unk
anyone know if Diversion 600 wheels are a lot lighter than stock?.....Me thinks they could work as disc sizes are identical
- Rod.s
Re: Diversion XJ6 wheels
Just remember to look at your hub width and the disc offset just incase you need to make allowances for this.
I had a magnesium front wheel from an xjr1200 for a while and the hub was slightly wider so spacer changes needed plus I needed to machine 2.5mm from the mounting points on the calipers to get them to sit correctly due to the wider hub.
Luckily the 17mm axle size was the same so 1 thing I didn't need to change was the bearings.
