tz250w
by tz250w » Fri Jan 07, 2005 5:18 am
TaZ (Max)
Wombat
- Forum Marsupial
by Wombat » Mon Jan 10, 2005 8:16 am
Max,
Can you do this tail light mod (cutting down the plastic lens) with the conventional bulbs, rather than LED or do you risk melting the plastic?
regards
Wombat
Red '97 TRX / gold wheels
tz250w
by tz250w » Mon Jan 10, 2005 3:02 pm
I think you'd probably end up melting the plastic. There's not a whole lot of clearance there. Also, you'd run into the problem of trying to seal it up. Not only that, but you'd never get it close to flush with the tail cowl.
The LED is self sealed, you can stick it in a bucket of water and it will lite up.
TaZ (Max)
Wombat
- Forum Marsupial
by Wombat » Tue Jan 11, 2005 10:57 am
Yeah, that's why I'm thinking of going with a "cat's eye" LED tail light (dimensions are 118 x 33 x 38mm thick) integral running/tail/brake light. Should fit nice and snug and look good too! There's a mob here in Sydney - AMC Motorcycle Components - that sell the unit for about $68 AUD. I think their address is
http://www.amcmotorcycles.com.au - then look for the headlight/indicator menu - I think its called LED Lite Diskrite
Wombat
aka Bob
Wombat
- Forum Marsupial
by Wombat » Fri Jun 09, 2006 7:53 am
Max, with the LED taillight, did you run a relay, or not worry about it?
I'm thinking of buying a ready made cat's eye unit or building up a cut down R1 unit with a set of 19 point LED bayonet globes (which I already have) a bit like Kev's taillight conversion.
Wombat
tz250w
by tz250w » Fri Jun 09, 2006 10:01 am
No, I just ran it off the wires that normally run to the tail... Never even bothered to check if there's a relay! lol
I wouldn't think it would be necessary, besides the LED units should draw much less power.
TaZ (Max)
Lada.s
by Lada.s » Sun Nov 05, 2006 1:37 pm
It looks very nice....
