Vee Two cams or other?
philk
Post by philk » Sat Jul 21, 2007 7:23 pm
Just bought some cams off ebay.....Quote:
Yamaha TRX850 performance camshafts
for the 270 degree crank engine,also found in the TDM 850
they have more lift & duration
when I had these fitted they gave 94bhp at the crank,
85bhp at the back wheel with a dynojet kit & Micron cans
Peak power produced at 7750 rpm ,so no issues about stressing the engine
only downside I ever found was slight lose at 4000
They are Australian made from billet & no machining of head or piston needed
Just drop in,check shims & hey presto instant 7 - 8bhp
The chap who dynoed it was impressed because he said a SP1 makes
110bhp at the back wheel & the TRX is lighter
There was a question around what make they were, the response was there were potentially two cam manufacturers in Aus.
One being Vee Two and a.n other and how can i tell which brand?
Is the claimed bhp reasonable?
All hail the HYPNO-TOAD
http://r33b.net/
wicky
Post by wicky » Sat Jul 21, 2007 9:51 pm
well fer what it worth me 99 TDM made 79.1 BHP on the dyno on thursda, road legal 2-2, K&N filthy, happy enuf with that tanks.
Re: Vee Two cams or other?
Post by Killerwhale » Sun Jul 22, 2007 1:09 pm
philk wrote:Just bought some cams off ebay.....Quote:
Where my question actually, wanted to know if the dude knew what he had in the bike. I thought the lobes looked.....strange.
Kinda black with scratches!?
Let us know how it goes!
philk
Post by philk » Sun Jul 22, 2007 2:10 pm
KW, some cams come with a coating on the which will wear off due to use. The matt coating looks like such a treatment..
But i wont know until i get them
http://r33b.net/
Post by Killerwhale » Sun Jul 22, 2007 5:37 pm
philk wrote:KW, some cams come with a coating on the which will wear off due to use. The matt coating looks like such a treatment..
Yeah, but wheren´t these long runners?
philk
Post by philk » Sun Jul 22, 2007 5:41 pm
heres the response i had from the email.
Hi Phil ,I had them in for a few months,but I had them second hand,there is
no sign of wear,just where its polished through use.
Maybe not a good photo?
http://r33b.net/
Post by phuk72 » Sun Jul 22, 2007 6:10 pm
I would guess V2 but in truth, unless there are marking on the cams, you have no real way of knowing. V2 designed their cams for top end gains which makes sense when he talks of 4,000 loss. (Wheras Kent reprofiled cams for more midrange.)
Saying that though, peak power at 7750 is fairly low. Mine makes peak power at 7500 but holds this through to nearly 9,000.
IMHO dropping cams in will not see gains of 7-8 bhp unless the engine is flowed and ported accordingly. Certainly, i didn't see that much power from a combination of cams, flowed and ported head but I don't have any experience of V2 cams (and personally wouldn't as it makes sense to target mid range and torque on a twin rather than outright power).
burty
Post by burty » Sun Jul 22, 2007 10:00 pm
OK, second hand info, so take it as it is:
I met a bloke a few years ago, who had V2 cams in his TRX, and IIRC correctly, no other engine mods. He told me he actually preferred the bike with the original cams. I think he said it was more rideable that way.
I don't mean to trash the cams, they are probably excellent. I suspect much of this is a matter of personal preference.
:D
philk
Post by philk » Sun Jul 22, 2007 10:25 pm
It is not my intention to leave the engine standard.
1. cams and Keihins first
2. Rods,pistons, gas flow to follow in the winter months
http://r33b.net/
burty
Post by burty » Sun Jul 22, 2007 11:17 pm
That sounds sensible.
Post by phuk72 » Mon Jul 23, 2007 8:57 am
philk wrote:It is not my intention to leave the engine standard.
Phil
if I were you I'd save your money and not buy rods - aftermarket ones are made from 'unobtainium' and effing expensive.
philk
Post by philk » Tue Jul 24, 2007 6:03 pm
KW cams arrived and it was as i suspected, they are practically brand new, they still have the coating on and are not scored in any way.
http://r33b.net/
Post by Killerwhale » Tue Jul 24, 2007 6:09 pm
philk wrote:KW cams arrived and it was as i suspected, they are practically brand new, they still have the coating on and are not scored in any way.
That´s super!
Keep us updated when installed etc.
mickjmag
Post by mickjmag » Wed Jul 25, 2007 1:11 pm
Have spoken to a couple of people that have gone down the avenue of v2 cams and they went back to the original as the hp gain was non existant without other major engine mods, these people raced their rex's and they stressed that the trx valve train is not up to the job if you intend on leaving the cams in for extended amounts of kms.
I've seen an article on v2 cams and what they claimed seemed to be rather optimistic :roll:
If it was me looking to fit them I'd do some serious research before pulling my engine to bits for no real gain!!!
Cheers, Mick
Post by phuk72 » Wed Jul 25, 2007 7:18 pm
mickjmag wrote:Have spoken to a couple of people that have gone down the avenue of v2 cams and they went back to the original as the hp gain was non existant without other major engine mods, these people raced their rex's and they stressed that the trx valve train is not up to the job if you intend on leaving the cams in for extended amounts of kms.
Cheers, Mick
I've heard that as well
