Rear sprocket...
TWISTEDTWIN
Rear sprocket...
Post by TWISTEDTWIN » Tue Sep 25, 2007 9:23 pm
Hi everyone!
After introducing myself (in the dedicated part of the site...)I started a dibate on the tall first gear on my trx.
Dropping the front sprocket to 16t was the first suggestion but then Killerwhale said that upgrading the rear one to 43t would have the same effect without stressing too much the chain.
I can not find a website (uk) wich can supply me one, any suggestions?
Post by trixynut » Tue Sep 25, 2007 9:48 pm
http://www.bandcexpress.co.uk
Might not be listed on the website, but give them a call.
Post by youngy » Tue Sep 25, 2007 10:03 pm
kebab19
Longer chain needed for larger Sprocket size?
Post by kebab19 » Thu Sep 27, 2007 1:23 pm
Following on from aftermarket sprockets:
If I switch to something like a 17 / 42 sprocket combination, do I need a 112 or 114 link chain instead of the standard chain length?
Post by phuk72 » Thu Sep 27, 2007 4:34 pm
The 42t sprocket is an option for a TDM900
B&C Express will give you the guidance on this
And yes, you will need 2 extra links over standard if buying a new chain
TWISTEDTWIN
Post by TWISTEDTWIN » Sun Sep 30, 2007 9:00 pm
...so...changing the rear sprocket to 42t or more needs a longer chain while a 16t on the front lets you get away with the standard chain (I just replaced the chain... :? )..if that's the case i think I will forget the rear sprocket option! :D
In the stables...:
TRX
KTM380SX
BMW G/S
BMW Cafe Racer
Post by phuk72 » Mon Oct 01, 2007 8:07 am
TWISTEDTWIN wrote:...so...changing the rear sprocket to 42t or more needs a longer chain while a 16t on the front lets you get away with the standard chain (I just replaced the chain... :? )..if that's the case i think I will forget the rear sprocket option! :D
Depends on wether your axle has room to move forward on the swinging arm.
brush
Post by brush » Mon Oct 01, 2007 9:35 am
mine trx has 17 front 43 rear no problem fitting standard length 525 chain
pwmotorsports
Post by pwmotorsports » Mon Dec 31, 2007 8:59 pm
mine being Stock needs some jiggery pokery now its naked so whats the recomendations ? want about 120MPH top ideally but really want to make it work as well as it can 0-100 more bottom end stomp being the main aim
Post by ekoja » Mon Dec 31, 2007 11:17 pm
pwmotorsports wrote:mine being Stock needs some jiggery pokery now its naked so whats the recomendations ? want about 120MPH top ideally but really want to make it work as well as it can 0-100 more bottom end stomp being the main aim
This could help
I'm on dailup (a exhilarating experience) and it does take some time to load.
