K&N pod filters...
Posted: Wed Oct 10, 2007 5:20 pm
Anyone know wich pod filters that fit the vel stack adaptor 85-3000
...kinda wierd measure....2 7/16 inch....
or 62mmKillerwhale wrote:Anyone know wich pod filters that fit the vel stack adaptor 85-3000
So it´s 62mm....well....we got the metric system way back so.....steve speed wrote:or 62mmKillerwhale wrote:Anyone know wich pod filters that fit the vel stack adaptor 85-3000
....this one is for keihin flatslides....so you know.devlin wrote:Just having a look at getting some pod filters. Are the 85-3000 adapters the only ones that fit the TRX? What length filter will fit under the tank without the air box?
phuk, been thinking of that a bit...phuk72 wrote: Also, a word of advice. If you do junk teh airbox, buy another filter to go over the end of the crank breather.
Super Ten had this. You can do it. Makes no odds apart from mess if it blows oil out. And makes an extra 1 - 2 bhp when it's not restricted by the airbox.Killerwhale wrote:phuk, been thinking of that a bit...phuk72 wrote: Also, a word of advice. If you do junk teh airbox, buy another filter to go over the end of the crank breather.
The crank breather hose is also an oil out if something goes wrong isn´t it....and what happens if you stick a filter directly on there....?
Wouldn´t it be better to have an oil catch tank and then an air filter (like Max had on the 4hr run?
The filter just stops vapour spraying onto your nice clean engine and stops the breather hosing oil onto your wheel in the event of a mishap.Killerwhale wrote:phuk, been thinking of that a bit...phuk72 wrote: Also, a word of advice. If you do junk teh airbox, buy another filter to go over the end of the crank breather.
