Ceramic liner?
Sp!ke
Ceramic liner?
Post by Sp!ke » Wed Oct 24, 2007 1:33 pm
I've been following a very long thread elsewhere where someone is doing the dongs danglies conversion of a S10 into something more closely resembling a YZE850.
One of the engine mods proposed is sending off the barrells to http://www.poeton.co.uk/ whi will apparently overbore the barrels and fit a ceramic liner. I note they also offer coatings for other engine components too to reduce friction and wear.
Anyone had any experience of doing the liners? The cost seems reasonable (£200) and if it cures the oil consumption issue like on the 900's it seems like it might be a worthy mod.
Anyone got any thoughts/experiences?
Post by phuk72 » Wed Oct 24, 2007 1:59 pm
Certainly sounds reasonable (although you have got to lose a shit load of oil to recoup £200!)
And not sure that the ceramic liner alone will cure oil consumption though. Oil passes the rings and valve seals.
And some of us already have nil oil consumption.
Janitor
Post by Max » Wed Oct 24, 2007 2:29 pm
phuk72 wrote: And some of us already have nil oil consumption.
\:D/
Janitor
Post by Max » Wed Oct 24, 2007 2:31 pm
Well, that is if you don't count the tempura, fried chicken, occasional double cheese burger... :oops:
Silver
Post by Silver » Wed Oct 24, 2007 3:04 pm
And of course the curry and chips at Mallory....oops that was supposed to be our little secret.
Post by Quan-Time » Wed Oct 24, 2007 3:46 pm
The oil consumption on the TRX is inherent by design flaw.
5v head + dry pump'd pressure sump. Changing to 4v heads, wetsump but relocated gearbox (bring it higher out of the oil) and splash lube it, few other tweaks, you can really cut down on the burning of oil.
Using a bore coat (such as nicosil, tinite, etc) it will lower oil NEEDS, not its burn rate. By lowering the oil pressure, you can do this, but you need to be fairly retarded to do this.. As the whole oil system will suffer.
Its possible to reduce oil burn rate by changing over your rings and oil retainer ring (the wavey one). Different shaped waves retain different ammounts of oil. So by using different brand of rings will alter the oil usage.
Piston design (skirt, oiler holes, etc) also plays quite a role in all this.
If you were really worried about how much oil you burn, do what the F1 boys do (and from what i heard once, one MotoGP team trialed). Pure ceramic bores and pistons. Indy cars have done it aswell for a while. They run zero clearance and only one piston ring (mainly for sealing purposes rather than oil scraping duties). Problem is you cant run the engine cold.. You artificially heat the engine and oil before you can even start it.
Just be thankful we dont have 2stroke's.. now THEY burn oil.
Chris
Re: Ceramic liner?
Post by Chris » Thu Jun 19, 2008 11:43 am
Hi,
Do you have the link to the original thread? sounds interesting
Chris
Trixz
Re:
Post by Trixz » Thu Jun 19, 2008 3:50 pm
Quan-Time wrote:....Problem is you cant run the engine cold.. You artificially heat the engine and oil before you can even start it.
That's a tiny problem I guess :roll:
:lol:
Can't bother much about a bit of oil consumption, as said, it's common. Also no oil consumption as well for some of us... (Max is one of them as I read )
Re: Ceramic liner?
Post by Quan-Time » Tue Jun 24, 2008 2:40 pm
mine does burn / consume oil, but it still goes 5,000km without topping it up. And thats service interval for me anyway. I guess its very hit and miss. weird.
Re: Ceramic liner?
Post by Killerwhale » Tue Jun 24, 2008 3:16 pm
Quan-Time wrote:mine does burn / consume oil, but it still goes 5,000km without topping it up. And thats service interval for me anyway. I guess its very hit and miss. weird.
Holy crapper, i´ll be topping up every 200km!! :shock:
...but you had the 900 yeah!?
biker_jay
Re: Ceramic liner?
Post by biker_jay » Sun Jun 29, 2008 3:29 pm
Does anyone know if the newer tdm 900 suffers from the high oil consumption?
I neglected to check my oil enough and resulted in a seized inlet cam, that was nice.
idl1975
Re: Ceramic liner?
Post by idl1975 » Sun Jun 29, 2008 5:40 pm
biker_jay wrote:Does anyone know if the newer tdm 900 suffers from the high oil consumption?
Think it's been suggested in one of the threads on TDM 900 engine swaps that one of the benefits is reduced oil consumption. Not sure whether that's true though.
'04 Aprilia Tuono Fighter
'00 Scooby Sport Wagon
'76 TY250.
Re: Ceramic liner?
Post by youngy » Sun Jun 29, 2008 10:24 pm
Have you checked the timing gear on the crank? If not, do so, as there may be a few teeth missing.
biker_jay
Re: Ceramic liner?
Post by biker_jay » Sun Jun 29, 2008 10:37 pm
youngy wrote:Have you checked the timing gear on the crank? If not, do so, as there may be a few teeth missing.
From the sezure? I didnt check it, it happened a few years back. It didnt lock solid just kept spinning. I didnt notice it untill i took the top off to check the clearences. It runs fine now. Took about 30 hours for me to work a new profile for the cam to run on.
Re: Ceramic liner?
Post by youngy » Sun Jun 29, 2008 10:44 pm
you were very lucky then.
if the inlet cam seizes, which is not uncommon, it is not unusual for the inertia in the crank to keep the crank rotating, which strips teeth off the timing gear on the crank as the timing chain has stopped moving at the camshaft, until a piston meets some valves.
