This isnt a 100% completed guide at this stage, but it will hopefully be a very good source of information on the subject.
TDM900 THROTTLE BODIES
As you can see, its possible to bring these out to 42mm ID fairly safely. Remember that stock TRX carbies are 38mm, and FCR carbies are 41mm (unless you buy the 39mm version). By increasing the bore size, you would need to change the butterfly to suit. You might also want to make a bevel adapter before the air filter.. Think "tunnel ram" or funnel to increase air velocity. This can be measured on a flowbench, but keeping the same angle which its currently tapered at (im guessing 5degs included angle) should be plenty.
THOAT TO HEAD ADAPTORS
The top picture shows how the injector is placed and how some blending of the angles into nice radius would most likely help with CFM flow.
The middle picture shows how the height of the 2 adaptors is vastly different. The throttles are the same length as the carbie models, but are located closer to the head, this would mean the stock airbox would require lots of modification, or simply adding on some pod filters would work fine, which is a much better option.
You can also see that the larger of the 2, the TRX stock item DOESNT have the "dip" in the bottom for the injector. The bolt holes are also different so the TDM adaptor DOES NOT bolt directly to the TRX head. The TDM adaptors provide no room for new holes to be drilled in.. Either a spacer plate or custom adaptor will have to be fabricated to fit, else an entire new head will need to be sourced.
The bottom picture shows how the dip would sit when bolted to the head.. Many hours of die grinding would need to be done to make this flow properly. The picture does not show it, but the walls on the head are approx 1mm bigger all around than what the adaptor plate is. This will help with air flow a touch, and means no further work other than the gouge for the injector need to be made.
You can also see that the bolt holes dont match up
THROTTLE TO HEAD FITMENT
The spacing for the throttles matches up well which means they can be used safely if new adaptors are fabricated, or a way to fit the TDM adaptors.
Even after having all this, you need to control the injectors. Theres 3 methods that i know of for this.
1: use the stock ECU module for a TDM900. It should be fairly straight forward, but you will need need to make a wiring harness or try to adapt the 2 together
2: Buy a PC3 for a TDM900 (power commander 3) and do the same as above. Will be flexible and dyno-tunable
3: Make a "Megasquirt" ECU unit. Megasquirt also provides the added bonus of being able to control spark, thus being even more tunable than the PC3 option.
MEGASQUIRT ECU (MS2V3)
The front of the MS has a data port (for linking to a laptop) and 3 LEDs, for quick reference (injector fire and or spark fire)
The back has a larger port to which you make your wiring harness, the small black plug is a barametric pressure guage, which means its capable of elevation correction (riding in hills or sea level) in realtime with no user / retune needed, and is also capable of 40psi turbo boost (auto rich / lean cycles).
Controlling spark would require you to machine the CAS (crank angle sensors) and making a 36-1 encoder wheel. This would be possible and i already have the CAD drawing ready and am halfway thru modding a pickup to accept this.
Thats about all for now.. I hope ive shed some light on the subject.
