You guy´s & gals with FZR400 head....
Post by Killerwhale » Wed Nov 28, 2007 8:03 pm
Just put in the double wopper and i was wondering how you solved the parking light?? Should have been done several times.....or maybe your MOT does not require one??
Kevtrx849
Moderator
Post by Kevtrx849 » Thu Nov 29, 2007 3:20 am
No, parking lights not required in Aus. You could always instal an LED under the fairing like i did. They use next to no power.
( HENRY FORD )
Post by Killerwhale » Thu Nov 29, 2007 7:19 am
Kevtrx849 wrote:No, parking lights not required in Aus. You could always instal an LED under the fairing like i did. They use next to no power.
Great idea!
Post by Quan-Time » Thu Nov 29, 2007 3:15 pm
heh, thats prolly the best thing ive seen ! very trick.
did you make the LEDs onto a board or somethin, or buy them as a bar / kit and just wire them in ?
Kevtrx849
Moderator
Post by Kevtrx849 » Thu Nov 29, 2007 6:52 pm
I bought them from Repco as a pair of driving lights. 12 leds in each one although you can only see 6 of them. It actually clips into that recess like it was made for it. Piece of double sided tape stops it vibrating loose. Works very well in my dark shed at 3:30 in the morning.
( HENRY FORD )
Trixz
Post by Trixz » Fri Nov 30, 2007 9:58 pm
In the Netherlands it's an obligation for the citylight for a motorcycle with a Date of First Registration past 31 October 1997!
So with my 99'ish TRX I would have a problem with no citylight at all :?
But I will do a Xenon conversion on which I behold the citylight :roll:
The idea from KEV, a LED in the 'gap' is certainly a good option!
Ps. Mattias, I DO like your new avatar a LOT :twisted:
