Forks....again....
Posted: Tue Dec 11, 2007 3:28 pm
Theoretically, wouldn´t any 41mm forklegs fit if you got the right sized stuff at the bottom....spindle, wheel etc??
....and of cource if not the length is way off!
Caliper/disc line up could be a biatch i guess....?
Re: Forks....again....
Posted: Tue Dec 11, 2007 3:59 pm
Posted: Tue Dec 11, 2007 4:53 pm
Yes
Why would be the question
Posted: Tue Dec 11, 2007 6:00 pm
by youngy
Wot he said^^^^^
£900 is a lot for a pair of forks, eh? ThunderCat forks would be a good option for the money.
Posted: Tue Dec 11, 2007 10:13 pm
youngy wrote:Wot he said^^^^^
No, i ain´t going for the "more of the worth of the bike" stuff....
One interesting thing is the VTR stuff wich is 41mm.....
Posted: Wed Dec 12, 2007 4:09 pm
by steve speed
if by VTR you mean firestorm, i had one, a new one in 1998 the forks were not good i had to send them to maxton to get them sorted there's not enough rebound and to much compression which is not adjustable ,,you only have rebound adjust ,what some lads did was fit fireblade forks ,,hope this helps .....
Posted: Wed Dec 12, 2007 5:01 pm
steve speed wrote:if by VTR you mean firestorm, i had one, a new one in 1998 the forks were not good i had to send them to maxton to get them sorted there's not enough rebound and to much compression which is not adjustable ,,you only have rebound adjust ,what some lads did was fit fireblade forks ,,hope this helps .....
Nah, in that case the SP2 fork...same 41mm but "real" forks!
Posted: Wed Dec 12, 2007 5:07 pm
by youngy
SP2 forks are 43mm USD
95-98 CBR600 had 41mm cartridge forks. 95-97 ZX-6R had them too.
Posted: Wed Dec 12, 2007 7:06 pm
by steve speed
whats holding you back from going the R1 way there's loads of bits on evilbay
Posted: Wed Dec 12, 2007 7:49 pm
youngy wrote:SP2 forks are 43mm USD
Asked a breaker to measure the SP2 USD forks and he was certain at 41mm!?
Posted: Wed Dec 12, 2007 7:50 pm
steve speed wrote:whats holding you back from going the R1 way there's loads of bits on evilbay
Just put the question out there, will most certainly keep the forks as i at least has Ohlins in ´em!
Posted: Wed Dec 12, 2007 9:28 pm
by youngy
Then I'd say he's wrong. Check the Race-Tech website. They list each model with fork sizes.
Even if he was right, they'd be no good cos they won't fit your yokes will they? So if you're gonna change the yokes, you may as well fit "any" front end....R1, YZF750 etc.
Only advantage of 41mm RWU forks is they fit the TRX yokes.....or am I missing something here?
Posted: Thu Dec 13, 2007 7:29 am
I´ll let him know his gauge is not calibrated!
(he want´s a sell i guess!)
Posted: Thu Dec 13, 2007 7:33 am
by youngy
Posted: Mon Dec 17, 2007 1:34 pm
by dfh
Killerwhale wrote:Just put the question out there, will most certainly keep the forks as i at least has Ohlins in ´em!
Ohlins what? Just forksprings hardly qualifies for the sticker...
DFH
