High velocity porting....
Post by Killerwhale » Mon Feb 25, 2008 1:07 pm
Well, a small sideproject before this season....
I´m going to try high speed port the head. Don´t know if it´s good for the trix but i like to have something to do.
Bought some welding material on ebay just now....
Will let you know the results...
steve speed
Re: High velocity porting....
Post by steve speed » Mon Feb 25, 2008 1:44 pm
have you been on motomans web site ? iam going to run in my new rings as he says when i get round to it at the end of this year
Post by Killerwhale » Mon Feb 25, 2008 1:49 pm
steve speed wrote:have you been on motomans web site ? iam going to run in my new rings as he says when i get round to it at the end of this year
Found his site a couple of years ago but he rants to much! :)
There are some Swedish sites about "D-porting" wich are more compressed when it comes to text....
Should be a fun project, but i have to change tyres and go for a dyno run first....
steve speed
Post by steve speed » Mon Feb 25, 2008 2:00 pm
i dont know if i dare stick something in the inlet port ,,,if it ever lets go the motor will be history ,,personally i just want a motor that doesnt use as much oil and is reliable ,,i have had R1s but they are NOT as good as Trixy on the road ,,perhaps iam just getting old ........ bugger........
Post by Killerwhale » Mon Feb 25, 2008 2:57 pm
steve speed wrote:i dont know if i dare stick something in the inlet port ,,,if it ever lets go the motor will be history ,,personally i just want a motor that doesnt use as much oil and is reliable ,,i have had R1s but they are NOT as good as Trixy on the road ,,perhaps iam just getting old ........ bugger........
Bloody ´ell, i´m 36 on wednesday!! #-o
Post by Greg » Mon Feb 25, 2008 4:34 pm
I'm with Speedy on being very very VERY (get the picture?) reluctant to glue anything into the inlet port/manifold... [-X
I got one of Phuk's old heads, and the half which remained identifiable as a cylinder head had been ported and I couldn't see anywhere that had been built up with additional material, just all surfaces smoothed and matched to the rubbers with a knife-edge on the bridge... It all looked very achievable with a die grinder or a small flap-wheel on a flexible drive.
G
:motard:
steve speed
Post by steve speed » Mon Feb 25, 2008 5:33 pm
hopefully qant will be along soon and show us what hes done ,,motomans idea for those who have not seen his work is to close up the inlet ports near the valve ,,this increases the gas speed into the chamber ,,,he backs this up by having a faster engine than the works bikes ( R6),,,, has anyone else got any input ??
Post by Killerwhale » Mon Feb 25, 2008 6:10 pm
steve speed wrote:hopefully qant will be along soon and show us what hes done ,,motomans idea for those who have not seen his work is to close up the inlet ports near the valve ,,this increases the gas speed into the chamber ,,,he backs this up by having a faster engine than the works bikes ( R6),,,, has anyone else got any input ??
All i know apart from that is that it´s kinda standard in Sweden, all bike have not been tested though.
And to correct above post....it´s not talk about glue anything here....
steve speed
Post by steve speed » Mon Feb 25, 2008 7:27 pm
sorry killer have i got it wrong ..again, i thought jb weld was a two pack epoxy glue,, do you not intend to do the same as motoman ?ie fill the inlets up with jb weld , and then reshape the ports, or am i getting the wrong end of the sticky,,sorry #-o #-o #-o #-o
Post by Killerwhale » Mon Feb 25, 2008 8:56 pm
Maybe just language problems, i would call it liquid metal more than glue....it´s fekkin hard to work on. Last time i used it on a boat prop and it´s truly is cold welding!
Post by Greg » Mon Feb 25, 2008 9:16 pm
Yuppers .. but it's still a two part epoxy resin based glue (call it what you will) with metal powder to reinforce it..
My immediate reaction is no no no, but I'm always open to persuasion (just ask Mrs Baker on the third Friday in months with an R in them..!)
G
:motard:
steve speed
Post by steve speed » Mon Feb 25, 2008 9:35 pm
i think you will find its slow cure epoxy with something like aluminium filings mixed in ,,i know motomans done this and iam sure others will come in more on the technical side but using this or any product that is glue ,and you run the risk of delamination as you know aluminium starts to corrode in about a Minuit so even when its bare alloy its already started to oxidize ,so in effect you will be trying to stick this product to powder ,,not good,,then there's the problem of heat expansion on the two different products ,,alloy and epoxy ,the whole area is constantly being washed by petrol ,,and in my layman's view its a recipe for disaster .... but good luck and keep us updated
steve speed
Post by steve speed » Mon Feb 25, 2008 9:36 pm
greg you beat me to it ,,,,,buggerit
Post by phuk72 » Mon Feb 25, 2008 9:48 pm
fine in a race engine that get's rebuilt every 6 hours
road bike - no thanks
Post by youngy » Mon Feb 25, 2008 10:20 pm
I've seen this done on ZX-7Rs a fair bit. They suffer from, amongst other things, oversized inlet tracts giving slow intake velocity.
The idea, of course, is to narrow the inlet and increase velocity. At the same time you can also have a very rough dimpled surface to increase turbulence and improve burn.
It would pay to roughen the inlet on the head first to lessen the likelihood of this stuff breaking off.
I just used JB Weld to fix a set of crankcases. A colleague at work tells me REME use this stuff to repair armour on tanks.
It is very strong stuff and I wouldn't be scared of (someone else) doing this with it.
