Bafflectomy
Red Rex
Bafflectomy
Post by Red Rex » Fri May 30, 2008 6:39 pm
To release a few extra dB's from standard cans ...
Scribe a line on the end of the silencer using the chrome end cap as your guide.
Chain drill along this line with a 3mm drill.
Join the holes and pull out the silly little pipe thingy.
File the edge of the nice new big hole to make it smooth and look nice.
Now you can either replace the chrome caps now and go for a ride, or if that's just a little too noisy you will need to make a baffle plate from a disc of sheet aluminium, like this ...
which fits under the end cap. All the little holes add up to a bit more than the original 'standard' pipe area (plus a bit to be sure not to restrict gas flow of course). Still sounds 'grrrrrrrrrrrrrrrrrreat' but doesn't annoy the plod so much.
An hour in the garage well spent !!!!
philk
Re: Bafflectomy
Post by philk » Fri May 30, 2008 7:10 pm
:shock: :shock: :shock: :shock: :shock: =D> =D> =D> =D> =D> =D>
Should sound better
All hail the HYPNO-TOAD
http://r33b.net/
gregs656
Re: Bafflectomy
Post by gregs656 » Fri May 30, 2008 8:23 pm
now that's tempting. nice job.
The Hunt Continues . . .
Re: Bafflectomy
Post by ekoja » Sat May 31, 2008 12:39 am
Or you can go down to your local hardware shop and buy ready made drainers which fit over the plug/sink hole which will fit perfectly.
Thanks to Kev, =D> I did mine in about 10 mins, thats assumng that the baffle has already been taken out. =D>
Much more user friendly.
petebucket
Re: Bafflectomy
Post by petebucket » Mon Jul 14, 2008 1:02 pm
Hey..as a newby I would like to thank Red Rex and Ekoja for their tips :)
I performed the BAFFLECTOMY on the weekend...the result is awesome.
Looks good..sounds great 8)
Thanks Guys =D>
HEATZ
Re: Bafflectomy
Post by HEATZ » Sun Oct 12, 2008 12:56 am
ummm im new to the TRX how loud is it with the baffle taken out?
same as race can or less?
i likes em loud me :lol:
(heres the can on me R1 :wink: )
Banger
Re: Bafflectomy
Post by Banger » Mon May 18, 2009 1:14 pm
tried bafflectomy but all 6 allen bolts are spinning has anyone encountered this and is there a easy fix
the TRX made me do it officer!
Banger
Re: Bafflectomy
Post by Banger » Mon May 18, 2009 3:17 pm
Ignore above, just completed the bafflectomy and what a fookin noise...I love it, I'll have to roll gently past the rozzer station at the end of our street but feck it,it sounds gorgeous!!!! :twisted: :twisted: :twisted: :twisted: :twisted: :twisted:
Trixz
Re: Bafflectomy
Post by Trixz » Mon May 18, 2009 3:50 pm
HEATZ wrote:ummm im new to the TRX how loud is it with the baffle taken out?
What can on the R1 :silent: *is that really a can... why don't get a pipe only :wink:
About your question, I do think it's not as loud as a race can (without the baffle), but just a bit more to hear the can's roar :wink:
devlin
Re: Bafflectomy
Post by devlin » Tue May 19, 2009 12:12 am
I just cut the baffle on my first TRX about 2-3mm from the body. As you say the resulting carcophany was glorious and raucous. :D Surprising how much that affects the sound dynamic.
Banger
Re: Bafflectomy
Post by Banger » Tue May 19, 2009 12:18 am
got home a little while ago after a 60ml round trip and i love the change in sound especially through bridges and echoing off the trees down country lanes :twisted:
devlin
Re: Bafflectomy
Post by devlin » Tue May 19, 2009 1:49 am
It never stops producing pants expanding sound. I always give it a blat going through a tunnel or past a suitable sound reflecting surface and have a giggle with myself..
G Beale
Re: Bafflectomy
Post by G Beale » Tue May 19, 2009 9:32 am
devlin wrote: I always give it a blat going through a tunnel or past a suitable sound reflecting surface and have a giggle with myself..
It's not just me then. :lol: 8)
zod
Re: Bafflectomy
Post by zod » Tue May 19, 2009 9:40 am
Do you surgents think it's possible to make this mod revesable (put the baffler on and off)?
Banger
Re: Bafflectomy
Post by Banger » Tue May 19, 2009 10:38 am
you could quite easily refit the baffle and reweld it back in so long as you dont crush the middle end pipe when you remove it! With abit of imagination you could (and i think I'll devise a method) of making it simple to remove/replace whenever it takes ya fancy
