Hagon shock
Posted: Sun Dec 21, 2008 11:31 am
by spookedbones
It´s time to do something with the back suspension. I can´t afford an Öhlins. The Hagon shock is half the prize of an Öhlin here in Sweden and not that much more expensive than letting an expert renovate the OEM shock.
What is the best choise; Put the money on a new Hagon or renovate the OEM?
Re: Hagon shoch
Posted: Mon Dec 22, 2008 12:36 am
by spookedbones
shock
Re: Hagon shock
Posted: Mon Dec 22, 2008 7:31 am
by Jak
There you go ... changed it for you
Re: Hagon shock
Posted: Mon Dec 22, 2008 9:46 am
by spookedbones
thanks
Re: Hagon shock
Posted: Mon Dec 22, 2008 9:49 am
by idl1975
spookedbones wrote:It´s time to do something with the back suspension. I can´t afford an Öhlins. The Hagon shock is half the prize of an Öhlin here in Sweden and not that much more expensive than letting an expert renovate the OEM shock.
I would go for a Hagon or basic EMC unit with the correct spring rate for your weight, intended use and the front end.
I do like my Ohlins shock
but really it's just "icing on the cake" - more important to get the spring rate correct and some sort of functioning dampening. Both the Ohlins and the WP on my Duke II felt very "plush" compared to my stock shock, so I wouldn't worry too much about not having enough damping from the Hagon - that's probably the better setup for road use.
I don't recall what your front end is, but looking at the Racetech website, replacing the fork springs and giving the forks a service while you're replacing the old shock would be a good idea. The stock TRX ones, according to them, have a rate about 50% of the recommended figure!
Re: Hagon shock
Posted: Mon Dec 22, 2008 10:33 am
by trixynut
I ran a Hagon rear shock for a while. It was good, but replaced a standard one that had done 15,000 miles so was bound to feel better.
Re: Hagon shock
Posted: Mon Dec 22, 2008 4:23 pm
by spookedbones
My thought too. The stoch fork is getting a service and new springs from Wilbers.
