hint: cheap programmable ignition
Posted: Fri Jan 09, 2009 3:44 pm
Been looking around for a programmable ignition for my upcoming engine revamp. I thought I'd share what I've managed to find in the net. I finally found fairly cheap and professional looking unit just under 200 euros with shipping.
Besides having TPS (or MAP) input, coolant temperature compensation (i.e. good cold starting), the unit also houses 5 second datalogger for power/torque measurement. That should be adequate for single gear WOT full pull. Poor man's dyno.
This unit will take the odd firing 270º crank as well, as long as cylinders have individual pick up coils.
Both ignition styles catered, TCI and CDI.
http://www.imfsoft.com/hardware/product ... on-cdi.asp
http://www.imfsoft.com/hardware/product ... on-tci.asp
BTW - I am not affiliated with, nor a stock holder of forementioned ignition unit manufacturer. This post is merely FYI.
