Blue spots on yzf750 forks? Help!
Posted: Sun Jan 18, 2009 3:39 pm
by idl1975
I've just been trial-fitting everything onto my YZF front end. The R6 calipers I have, which I thought would fit where my older blue spots don't, foul the brake carrier brackets. I.e. you can't bolt them up without the blue-spot bit of the caliper hitting the carrier.
Do I have to angle grind the carrier to make them fit (I know some people have done this...)? Or is there a secret model of bluespot caliper that definitely works?
Help! :shock:
Re: Blue spots on yzf750 forks? Help!
Posted: Sun Jan 18, 2009 5:11 pm
by trixynut
You have to modify the fork bottom to fit them, or use YZF calipers. Search on here: there was a post not long ago about it.
Posted: Sun Jan 18, 2009 5:18 pm
by honkdawillydahonk
Something like this is required...
Posted: Sat Jan 31, 2009 11:33 pm
by Terzikat
If you do modify the caliper mount to accept the blue spot calipers, do a good job of it. Smooooth profiles, not sharp edges and polished as smooth as you can. The mounting is under a fair bit of stress and is made of aluminium alloy which is prone to fatigue and cracking. I you do a really nice job of it like honkdawilly's it should be fine.
Posted: Sun Feb 01, 2009 10:31 am
by Tarwetijger
Actually I agree with Terzikat, but here's how I did it.
With the 320mm YZF dics, I also had to angle grind the brake pads a little, or they will hit the... don't know what they are called. Well, the brake pads will be to big! 8-[
Posted: Sun Feb 01, 2009 11:04 am
Tarwetijger wrote: With the 320mm YZF dics, I also had to angle grind the brake pads a little, or they will hit the... don't know what they are called. Well, the brake pads will be to big! 8-[
To clarify this point: OE YZF discs are a 'narrow track' design to work with 6 pot calipers... Ducati or similar discs can be used with Blue spots without modification....
