Question for you knowledgeable lot:
I`ve just secured myself a complete 1994 YZF 750 front end,complete job lot,yokes,forks,six pot calipers,wheel,guard,even getting the master cylinder and lines thrown in,200 quid!
Now,can I make sure of my own belief that all I need to do is change the YZF stem for a stock TRX one?
I plan to keep my fightered look so will either have to drill top yoke and fit some bar clamps,or look out for a custom/straight bar top yoke conversion.
Anyone got one of these or can point me in the direction of any suppliers?
Now I`ve ridden a YZF(1995)years ago but for the life of me cannot remember the type of damping/rebound on an early(one year into the production run)model.
The forks are black in colour,did I remember wrong,I thought they were gold anodised?
I don`t think they`ve been painted.
UPDATE:
I`ve now picked up the YZF front end and the forks are not adjustable in any way.
Also when tipping them up and down the oil sounds to be of a very low viscosity,does anyone have any schematics of early YZF forks and could post them on the forum or photocopy them and post out to me?
Oil volume and grade specifications would be useful too.
Ok,another little brain picker,the emulsion tube problem(carbs),are the factory pro ones I`ve seen on ebay made of steel,stainless steel,or nickel plated brass,anyone know?
And FORTY quid?That seems bloody steep to me,I could likely make some a LOT cheaper than that in a workshop available to me if I knew the exact dimensions.
I`m wondering if Allens could contact Mikuni on my behalf to obtain the said dimensions,after all it`s difficult to extrapolate dimensions from already(albeit slightly)worn ones.I`ve got a spare set of carbs but sadly those are in even worse shape!
I`m on a roll now,so here`s some more questions;
Anyone disconnected the OE water pump(saves a BHP or so)in favour of a thermostatically controlled electric one?
There`s an opportunity here to also get rid of the bloody great Yamaha thermostat too remember.
Oh and before I go,anyone got a spare coolant stub?
That`s the one that`s held in the head with an M6 cap screw,and pickles away like mad.
Mine is very scabby and the O/D looks to have diminished somewhat,I`m thinking of getting a stainless one fabricated but if I can source an original in good nick I`ll just Hammerite it and bake it on in the oven.
Nowt nicer than the sweet smell of a freshly baked,Hammerited bike part.
I`m considering adding some stainless frame rails along the tube run where the rear footrest hangers bolt on.
Think 200 mm long stainless kitchen cupboard door handles for an idea of their shape.
Some `hacksaw harry`(before me) has been at the luggage lugs and left a mess,now there`s limited bungee points as the imbecile has also cut off the extension of the alloy footrest bracket and that`s another missing luggage holding point too.
Cheers members.
