YZF 6 pots - correct master cylinder?
Posted: Thu Feb 19, 2009 9:34 am
How do.
I'm using YZF 6 pot calipers with an R6 master cylinder and lever set up on a YZF front end. Originally I was going to use R6 calipers, but then realised (duh!) that would mean relieving the **** out of the carrier, and that made me a wee bit nervous. So I got some YZF calipers instead.
Having ridden a few miles on the YZF front end (fresh pads, full m/c with new fluid), the lever is now coming back very far. No pulsing that I can detect, the brake feel is good and I can still stop hard under road conditions but it appears to be inching closer to trapping my throttle fingers under hard braking. I can get it to touch the bar on setting "1" on the adjuster.
Is this because the R6 m/c internal diameter (14mm iirc) is too small and isn't pushing enough fluid for the larger piston area?
If so, does anyone think the original TRX m/c (15.'n' mm iirc) will work, as I still have the whole original brake lever assembly, or will I need to track down a YZF or aftermarket m/c of a different size?
Thanks in advance...
