Alternative Front Fork Bottoms Mudguard
Posted: Sat Mar 28, 2009 6:31 pm
by tbec407
Just fitted FZR600R Fork Bottoms, Mudguard and spindle to to TRX fork tubes, new oils and seals. Look better than originals "imho"
Cheers Brad
Re: Alternative Front Fork Bottoms Mudguard
Posted: Sat Mar 28, 2009 8:25 pm
by steve speed
looks good ,, a bit of a upside down look ,, and a lot more modern ,,,well done :D :D
Posted: Sun Mar 29, 2009 9:52 am
why didn't you just fit the complete forks - they have 41mm legs don't they?
Posted: Sun Mar 29, 2009 10:40 am
by Kayla
phuk72 wrote:why didn't you just fit the complete forks - they have 41mm legs don't they?
Maybe the legs were bent/rusted/generally knackered? Looks good though :D
Posted: Sun Mar 29, 2009 7:06 pm
by tbec407
No rebound damper adjustment on the FZR forks just preload
Brad
Posted: Mon Mar 30, 2009 10:25 am
I like that,really nice look,well done. :wink:
Posted: Sat Apr 25, 2009 12:32 pm
by G Beale
Brad
Forgive my ignorance here but do TRX forks have rebound adjustment then ? I ask as I've just bought/won a pair of foxeye forks which I intend to replace my TRX units with but would seem silly if they are inferior items ? I assumed they would be at least as good being the exact same age. :?
Posted: Sat Apr 25, 2009 5:48 pm
by Kayla
Brad
Yes, the rebound adjuster is the screw inside the preload adjuster. Can be turned 'on' or 'off' :lol:
Posted: Sat Apr 25, 2009 7:34 pm
by idl1975
The four position adjustment on the fork tops is a combined compression and rebound damping adjustment, IIRC.
Brad
Posted: Sat Apr 25, 2009 7:39 pm
Compression on TRX fork is set by oil IIRC... :lol:
Posted: Sun Apr 26, 2009 6:08 am
by Kayla
Killerwhale wrote:Compression on TRX fork is set by oil IIRC... :lol:
Yes. Preload and rebound only on the TRX.
Posted: Sun Apr 26, 2009 12:18 pm
by G Beale
Ok thanks for replies (even the silly ones :lol: ). If these FZR forks come with less on them than the TRX ones I'm thinking there might be a way of using the best bits from both to make 1 good pair. My TRX tubes have some very minor pitting in the chrome just above the area of travel & I just bought a YZF front mudguard which I'm hoping will bolt to the FZR forks without too much butchering. [-o<
Posted: Mon Apr 27, 2009 12:08 am
by dandywarhol
Yep, pretty cheap and nasty, the squirting of oil through sharp holes in the damper rods just makes the oil break up quickly and gives harsh damping. Better to junk the damper rod system for a pair of luverly Race Tech Gold Valve emulators and get 2 stage compression damping to sweeten the ride - the rebound will just follow on anyway :lol:
Posted: Thu Jun 25, 2009 9:17 pm
by BBB
look good,
Is it just the fork sliders and wheel spindle you used or did you need the spacers etc...
Thanks
Posted: Fri Jun 26, 2009 4:15 pm
by tbec407
BBB wrote:look good,
Thanks
TRX speedo drive, not sure on the spacer think I used the fzr600rr one
