My riding position
My riding position
Post by trixynut » Sun Apr 19, 2009 3:55 pm
Just been fiddling with my riding position as I find the bike a bit uncomfy after about 45 mins riding, but don't want to compromise handling or ground clearance, so here's what I ended up with:
1. YZF dogbones, raising the rear 25-30mm
2. Forks through the yokes with 25mm (including fork top caps) showing
3. Bars raised up the forks 15mm with spacers
4. Double bubble screeen
5. 120/70 front tyre
This is giving me sharp steering, pleanty of ground clearance, not too much weight on the wrists, makes me sit in the middle of the seat, and not too much wind blast.
Raising the bars up the forks has made a massive difference to how in-control I feel and makes the whole front feel lighter.
Dave.
steve speed
Re: My riding position
Post by steve speed » Sun Apr 19, 2009 7:23 pm
make it into a streetfighter you know you want to !!!!! :D :D :D
Post by trixynut » Sun Apr 19, 2009 11:34 pm
Nope, I don't.
:D
HolerTogni
Post by HolerTogni » Mon Apr 20, 2009 10:10 am
Hi trixynut!
trixynut wrote: ...
1. (YZF dogbones,) raised(ing the) rear 25-30mm
(2. Forks through the yokes with 25mm (including fork top caps) showing)
4. Double bubble screeen - only on my race fairing and not ridden yet; but on May 01 I will :twisted:
That's quite like my riding position and I enjoy it very much - have fun!
Positioned greetings from Munich!
TRX 850 & Racetrack-TRiXie
Post by phuk72 » Mon Apr 20, 2009 12:28 pm
trixynut wrote:Nope, I don't.
:D
well said that man :wink:
Jock414
Post by Jock414 » Sun Aug 02, 2009 9:30 pm
But how tall are you in cm ,thanks !? :D
Post by trixynut » Sun Aug 02, 2009 10:01 pm
about 183cm? (6ft 1inch in english)
Jock414
Post by Jock414 » Mon Aug 03, 2009 9:53 pm
Amazing i am 183cm :D my forks are 30mm up but i dont have the dogbones i do have the
120-70.
I think i will try your settings !
Did you shift the clipons left to right upsidedown?
Post by trixynut » Mon Aug 03, 2009 10:25 pm
Didnt swap the clip-ons over as I dont like the angles in makes. Just slid them up the fork leg, then put in a spacer under the bolt that secures them to the yoke.
Silver
Post by Silver » Tue Aug 04, 2009 8:48 am
Mine is about the same, 12mm higher bars and same as yours on the fork tubes. No dog bones though but same front tyre. Managed 1750miles in a week this year, but sore arse is still a problem.
Post by slow codger » Tue Aug 04, 2009 11:37 am
:D Had the bars like that for ages, just got the dog bones on Sunday from Philk.
Re the seat there is no padding in it so it has the feeling of a plank of wood, get it recovered and put some more foam in it!
Post by slow codger » Tue Aug 18, 2009 2:01 pm
:D Dogbones are on and been out for an hour and a half blast round the local back roads, The back end is higher yet I sit further back in the seat, how is that?? Handled well, however noticed a little muck flap on the rear of the standard mudguard now, that will be going!
gregs656
Post by gregs656 » Wed Aug 19, 2009 12:27 am
the biggest comfort issue I have is the seat. I have read somewhere that cutting off that little tapered section helps, not tried it though.
My left shoulder is an issue after the accident, but that's more to do with the dog shite SV hire bike than the TRX, so I can't really hold it against it.
The Hunt Continues . . .
