Front spring length???
Posted: Wed Apr 22, 2009 5:14 am
Does anyone know the length of a front spring for a std trx fork???.. Possibly on your replacement springs they have given these specs
either on the box or paperwork that comes with it???? I have found the free length of 381mm (limit) in the workshop manual which is the threshold when it should be replaced but not the actual length of a std trx spring to start with.
Any help would be greatly appreciated.. I have worked out the spring rate of .9kg/mm needed just need a length now...
cheers cobbadig
Re: Front spring length???
Posted: Wed Apr 22, 2009 11:06 am
by trixynut
Mate,
Dunno spring length soz, but just a pointer: the standard springs fit in with a spacer tube at the top (prolly about 70-100mm?) whereas replacement ohlins springs for instance are this much longer than the stock ones, so do away with the spacer.
Leads me to think how critical is spring length? As long as they are longer than standard, the spacer can be trimmed to suit, or a new one made up.
Of course, you need to know the length of the standard spring first...................
Dave
Posted: Wed Apr 22, 2009 3:43 pm
by slow codger
Can measure my import jobs hiding in the garage if you want.
Posted: Wed Apr 22, 2009 11:40 pm
Any help appeciated cheers....
Posted: Thu Apr 23, 2009 11:41 am
ones in the box I have are only 341mm long??? Hope there not too short...
Posted: Thu Apr 23, 2009 12:32 pm
A ph call to the shop i was told just to use a spacer to fill the gap if there is one there????? to me there would be a minimum length.... Standard .. for a reason.. would not this affect the absorbsion of the compression of the spring and bottoming out ???? Also durability and fade??? Maybe not so noticible if just a touring bike but I'm tuning this bike to work to thresholds so I'm sure these things would play some sort of part.. new spring length 341mm ... free spring length from manual..381mm... does this mean I'll only get 9/10ths of the travell before bottoming out in the front end... or am I putting too much into this????
Posted: Thu Apr 23, 2009 1:53 pm
by trixynut
The standard spring is, as you'll know if you've had the forks apart, under pressure i.e. you have to press on the fork top/damper rod to get it to thread into the fork tube, and ohlins springs are longer, as I said.
The yamaha tollerance figure is probably the limit for when it will not be under pressure any more, or has been compressed so often it's fecked.
So length shouldn't be too vital (thats what I tell the ladees anyhoo!
) as a fixed rate spring (as apposed to a rising rate spring like Hagon ones) regardless of length, IIRC, doesn't need more force to compress it more i.e. you apply x kg of pressure and it compresses y amount and thats true all the way until it will compress no more.
Your forks should never really bottom out ever, but isn't this governed by how nuch of the fork leg will slip inside the fork bottom, not by when the spring is fully compressed?
But at 341? hmm...........that could be a bit short??
However, I could be taking a load of bollox as usual.
Posted: Thu Apr 23, 2009 3:12 pm
by slow codger
Ok my 1995 Japanese spec import springs are 395 mm, the Euro ones were shorter, and had a gap, but I didnt put a spacer in and the Euro ones are still better.
Posted: Thu Apr 23, 2009 3:18 pm
still have the shorted ones around to measure by any chance???
Posted: Thu Apr 23, 2009 3:19 pm
by slow codger
They are in the forks!!
Posted: Thu Apr 23, 2009 3:32 pm
395 mm compared to 341mm thats 54mm over 2" does that sound about right from memory??? Maybe the longer spring was a progressive type ??? with no spacer would effect preload upon spring so spring rate comes into play... the shorter spring heavier oviously???
Posted: Thu Apr 23, 2009 6:24 pm
by slow codger
The Japanese springs are softer, bottom out very easily and shake the fillings out of your head!! The European ones are much better, at least I have some suspension now when braking hard! The compression on the Euro spec ones was harder whilst trying to compress by hand than the Japanese ones. Hope that helps. Re size, I think from memory that they were a good half inch shorter. They came from Youngy's garage lol, but then he did have a few TRX bits laying around
Posted: Thu Apr 23, 2009 6:56 pm
by dandywarhol
Cutting a standard spring and replacing the length with a spacer of the same length will make the suspension rate stiffer.
Posted: Sat Apr 25, 2009 3:09 am
Posted: Sat Apr 25, 2009 4:40 am
Here cobba,this may help you get your head around how springs work in relation to their rate,lenghts and wire guages:
http://www.moto-racing.co.uk/Guides/Lin ... ssive.html
And Hooke`s Law:
http://en.wikipedia.org/wiki/Hooke%27s_law
