Rear Wheel Upgrade
schmiffee
Rear Wheel Upgrade
Post by schmiffee » Thu Jun 04, 2009 7:50 am
I remember reading on here about a rear-wheel upgrade (5.5" as opposed to the standard 5") and I was just wondering what bike this would be off? I have the opportunity to purchase a front and rear wheel of a 1988 FZR1000 dimensions: Front 17x3.5 & Rear 17x5.5.
Will these fit? and if so is there any/much playing with them to make them fit or is it a straight swap?
Thanks,
Schmiffee
Re: Rear Wheel Upgrade
Post by trixynut » Thu Jun 04, 2009 9:18 am
Easiest way is with a YZF750 5.5" rim.
Search is your friend... :wink:
schmiffee
Post by schmiffee » Thu Jun 04, 2009 11:37 am
Is the YZF750 rim the same as the YZF1000 rim? Does the year model that it came off matter?
Post by trixynut » Thu Jun 04, 2009 12:42 pm
YZF one is easiest cos it uses the same sprocket carrier as the TRX and the disc lines up and is same diameter, just needs some new spacers making and different bearings as the TRX axle is thinner. Any YZF750 or YZF750sp will do.
Dunno about the FZR100 wheel, soz, but anything can be made to fit.
Post by slow codger » Thu Jun 04, 2009 4:33 pm
:shock: I had to turn the dished rear sprocket round on mine to make it line up.
Post by Killerwhale » Thu Jun 04, 2009 5:17 pm
slow codger wrote::shock: I had to turn the dished rear sprocket round on mine to make it line up.
...and i ordered an offset sprocket....
steve speed
Post by steve speed » Thu Jun 04, 2009 8:10 pm
my sprocket is also just filpped although trixynut did all the work on the spacers ,,,then painted it in racing lellow :D :D
Post by slow codger » Fri Jun 05, 2009 2:09 pm
:D Killer, did you get the sprocket sorted in the end.
Post by Killerwhale » Fri Jun 05, 2009 2:33 pm
slow codger wrote::D Killer, did you get the sprocket sorted in the end.
Yeah, had one custom made approx. 4mm slotted inwards.
steve speed
Post by steve speed » Fri Jun 05, 2009 2:58 pm
with mine fliped its 3mm offset and it runs true to the gearbox sprocket :D
Post by Killerwhale » Fri Jun 05, 2009 3:04 pm
steve speed wrote:with mine fliped its 3mm offset and it runs true to the gearbox sprocket :D
So for the future i guess i can buy a yammie standard and a 16 front and it would be ok...all standard are dished??
Really think my 16/40 is a tad hysteric now....
steve speed
Post by steve speed » Fri Jun 05, 2009 3:07 pm
well i am on 17/42 and yes it runs out of puff at about 135 mph but up to that its great :D :D
