Got the Thundercat forks fitted- at last!
Kayla
Post by Kayla » Sun Jul 12, 2009 8:55 pm
Here's a few pics of the Thundercat forks fitted to my bike. It was pretty straightforward and the spacers were perfect (thanks Greg!).
'Scuse the mess :lol:
Mmm... adjusters :D
YZF750 mudguard looks a little Bodgitt & Scarper at the mo- nothing a few minutes with a heat gun won't sort but it'll do for now :lol:
You should be able to see the new spacers between the speedo drive and spacer and fork legs. Can't get the last 10mm of the front scrubbed in ;)
Gratuitous FCR shot :twisted:
Polishing nerds- Yes, my bike is scruffy but it works and it's great.
I had to bite the bullet and fit higher bars as my back is a bit knackered at the minute. Hopefully clip-on service will be resumed soon.
Re: Got the Thundercat forks fitted- at last!
Post by trixynut » Sun Jul 12, 2009 9:26 pm
Nicely done! =D>
...and the only way you'll scrub in the last 10mm of a front is to low-side it!!
G Beale
Post by G Beale » Sun Jul 12, 2009 9:54 pm
"YZF750 mudguard looks a little Bodgitt & Scarper at the mo- nothing a few minutes with a heat gun won't sort but it'll do for now :lol: "
Kayla if you're refering to the bottom legs sticking out too much at the front then that's how they are. Got YZF one fitted to my FZR forks & it's the same as yours from the front, wider at the bottom. :D Looks fine to me. 8)
Post by cobbadiggabuddyblooo » Mon Jul 13, 2009 2:49 am
So will be waiting a taste test now mate.. Same length as the trx ones are they as such so can use your old springs if need be??(or space them to suit if slightly longer)Notice you have a rebound setting on the bottom of the fork to tinker with also.. You also have shorter dogbones too from memory dont you?? so a fair few mods done now suspension wise.... =D> =D> 8)
Kayla
Post by Kayla » Mon Jul 13, 2009 7:15 am
Thanks for the replies :D
cobbadiggabuddyblooo wrote:So will be waiting a taste test now mate.. Same length as the trx ones are they as such so can use your old springs if need be??(or space them to suit if slightly longer)Notice you have a rebound setting on the bottom of the fork to tinker with also.. You also have shorter dogbones too from memory dont you?? so a fair few mods done now suspension wise.... =D> =D> 8)
Yep, I'm taking it the long way round to work today :D The forks have compression and rebound and I think the springs are a higher rate than the standard TRX ones. The legs are the same length and I've got them set with 45mm showing above the top yoke. I just re-oiled the forks with 5wt (as standard T'cat) with the standard amount and they're set near enough standard on the adjusters so I've got a base to work from. New shock next!
Trixz
Post by Trixz » Wed Jul 15, 2009 3:13 pm
Your comment:
I was about to .... :wink: :lol:
Ps. 1996 TRX850 import. UK cdi, dynoed at one million horsepower, upside down exhaust, wavy tyres, carbon fibre toilet seat, blah, blah, blah... Image
Post by phuk72 » Wed Jul 15, 2009 6:21 pm
trixynut wrote:Nicely done! =D>
he's not wrong (well, it's virtually impossible to scrub them to teh edges anyway)
nice work btw
Kayla
Post by Kayla » Wed Jul 15, 2009 9:06 pm
Thanks all :D I'm going to go back to the clip-ons as although the higher bars are more comfortable, there's not as much feel and they're a little too 'IAM' for my liking :lol: I'll get some ally plate and make some plates to move the rearsets up and back too- in for a penny... :shock:
idl1975
Post by idl1975 » Fri Jul 17, 2009 8:26 am
nice work btw
Hey, I managed to scrub in the whole tyre on the right side...
...by _very_ nearly lowsiding it on a diesel-soaked roundabout.
Try it, it's fun! :roll: :D
'04 Aprilia Tuono Fighter
'00 Scooby Sport Wagon
'76 TY250.
Kayla
Post by Kayla » Sat Jul 18, 2009 2:56 pm
The forks seem to work well and feel plusher and more composed than the TRX forks but that could just be down to having fresh oil in them. The stuff that came out of them was like water, only runnier. I'm pretty chuffed with how it's turned out.
Post by Tarwetijger » Wed Aug 12, 2009 9:37 pm
Ah, I just love the white color scheme. Image
So get that fender painted please :twisted:
amiciangelo
Post by amiciangelo » Mon Sep 07, 2009 10:38 pm
Hello, I also want to mount on my TRX, Thundercat 600 forks, what should I do? You can change only the stems complete, or should also change anything else? (Excuse my english!!! :oops: :oops: :oops: :oops: )
Kayla
Post by Kayla » Wed Sep 09, 2009 2:30 am
amiciangelo wrote:Hello, I also want to mount on my TRX, Thundercat 600 forks, what should I do? You can change only the stems complete, or should also change anything else? (Excuse my english!!! :oops: :oops: :oops: :oops: )
Hiya,
All you need is the Thundercat forks as they fit straight into the TRX yokes. You need two spacers to go between the fork lowers and standard spacers. That's it! I'd advise you to measure your own spacers as every bike's different.
http://www.trx850.motomaniac.net/forum/ ... ers#p47576
amiciangelo
Post by amiciangelo » Wed Sep 09, 2009 12:37 pm
Thanks for the reply, since you've already made the change, if you do not create problems, you can give me the steps to build the spacers?
(This is the axis of wheel spacers?)
Post by Quan-Time » Thu Sep 10, 2009 11:25 am
gratz on the mod.. Look good. Also like your vapor speedo thing.. Tiny = good.
