Air Filter Foam in standard filter frame?
Posted: Thu Jul 30, 2009 3:19 am
by M.V.
Well, you're all about to find out how cheap I am! 8)
I have ordered some parts for the TRX, including a new airfilter, & I plan to gut the old one, remove the paper filter & put some filter foam in there. I'll put the frame back together with bolts.
I reckon it should free up a bit of airflow, which shouldn't be a problem, & will become washable, rather than throw away.
Can anyone foresee any problems with this?
Re: Air Filter Foam in standard filter frame?
Posted: Thu Jul 30, 2009 5:39 am
prob by the time you purchase the other filter and then the filter foam to mod the old one you could just go out and buy a K & N filter and have a washable filter for the same price anyways.. I made my own filter too modelled on the RAMAIR twinsock filter to fit over the stacks on my FCR's and it's working fine after bout 5,000km's and 6mths so far ( 20mm thick filter foam)
Posted: Thu Jul 30, 2009 5:45 am
I might add you will also notice a difference with the K & N filter down low they breathe a lot better.. First mod I made when I first purchased my TRX all them yrs ago.. :lol: :lol: good investment...
Posted: Thu Jul 30, 2009 7:17 am
by M.V.
Fair enough, I thought it might be worth a try if the foam was cheap enough, better than throwing the old filter out!
Posted: Wed Dec 02, 2009 12:51 am
by M.V.
Ok, so I did this, I have been running it for a month or so, in the next few day, I will swap over to the original & see what the differences are, stay tuned!
Posted: Wed Dec 02, 2009 11:42 am
If you search the threads MV you`ll find members who`ve gone to great trouble modifying standard airbox`s I believe Phuk was one such.
Kedo even market round push in`extra` filter elements for folk who go down this route,cutting holes in the front of the airbox housing.
Gains CAN be found but the better/less time consuming option is to junk the airbox altogether using K&N or Ramair filters. Best of all though get some big ole squirters for her(Keihin FCR41`s),you`ll be amazed at the extra ponies you`ll find you`re riding. :wink:
Posted: Wed Dec 02, 2009 6:35 pm
by Kayla
Mincehead wrote:Best of all though get some big ole squirters for her(Keihin FCR41`s),you`ll be amazed at the extra ponies you`ll find you`re riding. :wink:
This is v. true, even with a standard-ish airbox still fitted and if you do the TPS mod you'll find one or two more, allegedly.
Posted: Wed Dec 02, 2009 9:37 pm
Mincehead wrote:If you search the threads MV you`ll find members who`ve gone to great trouble modifying standard airbox`s I believe Phuk was one such.
Yep - I spent time and money trying to sort out the standard airbox / carbs. Gains are negligable.
Posted: Wed Dec 02, 2009 11:42 pm
by dandywarhol
Because Yamaha (and the other major players) spend millions of yen/euro/dollars to get a reasonable compromise between airflow and passing noise tests - then Joe Amateur comes along with a piece of memory foam and thinks they can do better - very, very occasionally Joe Amateur gets it right but more ofter gets it wrong......................do you really want to feck your cylinder bores/pistons and have even more oil burning issues?
Posted: Mon Dec 07, 2009 1:36 am
by M.V.
It was more a cost thing, rather than performance per se, $25 for enough air filter foam to make 4 x reusuable filters, vs $50 each for disposable Yamaha filters. Performance wise, as long as they weren't any worse, I would be happy.
dandywarhol wrote:do you really want to feck your cylinder bores/pistons and have even more oil burning issues?
You're meaning more air = less filtering, more crap in the engine, or is there more to it?
Posted: Mon Dec 07, 2009 4:01 pm
by dandywarhol
Thats what I mean MV - when you consider the engine is gulping in roughly 30,000 litres of air for every litre of fuel - that's a helluva lot of crap to potentially suck in......... :wink:
Posted: Wed Dec 09, 2009 1:15 am
by M.V.
I thought it would be more along the lines of 14.7 litres air/per litre of fuel...
Anyway, I'll take out the filter this weekend & see how dirty is is, then swap the original in & see what the differences are.
Posted: Wed Dec 09, 2009 9:01 am
by dandywarhol
14.7 to 1 by MASS, 30,000 :1 by volume...............next time you hear the induction roar on full throttle do you think you're putting in fuel at 14.7 times ratio? :wink:
Posted: Thu Dec 10, 2009 12:24 am
by M.V.
Ah, I see! The induction roar is very hard to hear over my Leo Vince slip ons :(
