FZR250/400 Projector Beam headlight
Posted: Tue Sep 01, 2009 11:41 am
by redkiwi
I've just purchased one locally for $60NZD (about 20GBP) - I know it mounts up fine, but will I need to modify the wiring loom and plugs? I don't pick my TRX up for another week so can't tell by looking :wink:
Re: FZR250/400 Projector Beam headlight
Posted: Tue Sep 01, 2009 3:10 pm
redkiwi wrote:I've just purchased one locally for $60NZD (about 20GBP) - I know it mounts up fine, but will I need to modify the wiring loom and plugs? I don't pick my TRX up for another week so can't tell by looking :wink:
I´ve cut the standard plug off....soldered the cables together and then the projector has a dual cabling...voila...
Posted: Tue Sep 01, 2009 8:48 pm
by Millsy
You dont have to modify any wiring just push out the connector spades from the TRX connector block and plug them directly into the FZR one.....simples,5 min job,at least it was on mine. :D
Posted: Tue Sep 01, 2009 9:14 pm
Millsy wrote:You dont have to modify any wiring just push out the connector spades from the TRX connector block and plug them directly into the FZR one.....simples,5 min job,at least it was on mine. :D
Strange, mine where not the same size :shock:
Posted: Wed Sep 02, 2009 8:50 am
nor was mine
there are some differences across the range as I have discovered to my detriment :oops:
