TRX chain Sprocket sets
SDN
Post by SDN » Sat Feb 06, 2010 8:18 pm
Any one out there know best value / performance chain and sprocket set for TRX? Had a look on E Bay range is bewildering
Kayla
Re: TRX chain Sprocket sets
Post by Kayla » Sun Feb 07, 2010 11:10 am
I bought a front sprocket and chain off Wemoto.com and a 40 tooth alloy sprocket from B&C Express. It came to less than £100, all in I think :D
Post by phuk72 » Sun Feb 07, 2010 6:50 pm
But the most expensive c&s you can afford. Cheap sets are a false economy
steve speed
Post by steve speed » Fri Feb 19, 2010 8:12 pm
the best but not cheap is the DID ZVM2 it has the highest tensile strength at 10370lbs,, i only use renthal sprockets :D
Post by Mincehead » Fri Feb 19, 2010 10:30 pm
steve speed wrote:the best but not cheap is the DID ZVM2 it has the highest tensile strength at 10370lbs,, i only use renthal sprockets :D
Yep good stuff but as Steve says fookin expensive:
http://www.mandp.co.uk/productinfo.aspx ... er3url=DID
Treat her well and she`ll outlast any other though. :wink:
