had a go at removing the Exhaust headers only to struggle with them.(Note freshly painted cam cover and Polished and painted wheels)
Earlier to taking the rather drastic action i had been reading through various posts it became clear that a set of Kawasaki Exhaust clamps could be persuaded to fit. Although the exact model of Kwak was not merntioned i had a look on the Bay and found a set of clamps from a GPZ1000RX so bought them thinking i could make them fit one way or another.
So after changing the studs to a set of 50mm stainless ones
i offered them up to find that they were almost perfect, a little persuading in my vice and Job Sorted.( I thought i had a completed photo but obviously not !)( Yep found it ! further down the post.)
The studs are now a bit long but i thought that in the event of finding a set of Large Bore downpipes i would leave the bolts long enought to fit. This have given me the opportunity to finally polish the downpipes as they should be.
So i have a set of exhaust Clamps that will fit a TRX so PM me if you are interested in having them for a £5 plus p&p. They will need a bit of bending to make fit but if i can do it, it can`t be hard !
