They won't be cheap, but they will be of the best quality, strength and precision you can get unless you happen to work at NASA.
TRX Rearset Prototypes
- tz250w
Please watch this thread over the next couple of weeks if you are interested in what 'will' be the best set of rearsets ever made for the TRX. My bike is the prototype, and I just took it over to the company today. Tomorrow we will be doing position measurements and once the CAD work is done they go into the CNC milling machine, an anodizing treatment after that and they will be ready for production.
TaZ (Max)
- tz250w
We have decided on a five postition adjustment range.
Compared to the stock peg position...
Imagine a square, with dots at the four corners. Each of the measurements below would represent one corner with the third measurement being a dot in the center of that square.
5mm Up X 25mm Back
5mm Up X 40mm Back
12.5mm Up X 32.5mm Back
20mm Up X 25mm Back
20mm Up X 40mm Back
Standard shift pattern and GP (Reversed) shift pattern an easy swap.
These positions were decided upon taking into consideration that the average gaijin has longer legs than the average Japanese and the fact that extreme race only positions would not be much fun when touring.
These are what they will look like (photo's are of the FZS1000 model). In fact, the shift lever will probably be the exact same part.
The COERCE steps I have been using until now were 20mm Up X 30mm Back. No clearance problems at the track but for my legs I wanted them a little farther back.
5mm Up X 25mm Back
5mm Up X 40mm Back
20mm Up X 25mm Back
20mm Up X 40mm Back
TaZ (Max)
- tz250w
- tz250w
Progress...
The CAD work is done and they are waiting in cue for a run through the CNC machine... If I can get a free second I'll try to run out there and grab a picture while they're being milled.
TaZ (Max)
- tz250w
Re: Progress...
Well... They are still cued. Should get their spot on the mill in a few days. In the mean time, here is the CAD drawing for the proto set.tz250w wrote:The CAD work is done and they are waiting in cue for a run through the CNC machine... If I can get a free second I'll try to run out there and grab a picture while they're being milled.
TaZ (Max)
- tz250w
Update
The prototypes have been milled and are now being fitted for the linkage. They will be sent out for anodizing this coming week so I should have some pictures of them mounted shortly after that.
TaZ (Max)
- tz250w
Taaaadaaaahhhhhhhhh!!!!!!!!!!
I picked up the completed prototypes today and have taken some pictures to show how they've come out.
There are five available positions that I have listed earlier in this thread.
Right when they hit my doorstep... Literally!
In the 40mmBack-20mmUp position with standard shift pattern... NOTE: The linkage arm on the transmission has not been properly adjusted in this photo. I just stuck it on there for the picture....
Brake side, same position. NOTE: I am using a cut-down standard Brake Fluid Reservoir hose that I shortened to match my old COERCE rearsets and TRC glass-fiber seat cowl. You may need to clip some off your standard hose to match the position you select.
Standard rear brake switch is retained along with its mounting bracket. The kit includes a longer spring to match.
Okay... Back to the left (shift) side. To switch between standard (1 down and 4 up) shift pattern and racing "GP" pattern (1 up and 4 down) all you need to do is switch the mounting point of the shift rod from the lower part of the pedal to the top. Of course you may need to adjust the length of the rod... Fortunately, there are plenty of threads for that.
The 'Five Position' holes in the back plate.
For comparison. The new 'prototype' rearsets, my old COERCE cheapos and the standard TRX steps.
TaZ (Max)
- tz250w
Okay.... Down to business...
I need 'monitors' or 'tester's that are interested in these rearsets. I have already received several emails from interested people, some not even on this or the main TRX forum.
Those of you who have already contacted me, please send another mail just in case. I know it took a long time from the announcement the first prototype so I have a ton of email in my box since your last message. I will make sure that those who spoke up first have top priority.
However...
I need people spread around the major TRX populated regions. Australia (regional) U.K., Europe, etc. Please email me if you are interested, they will not be free of course but you will get them at a considerably lower cost than the retail amount. (Still to be announced)
For the time being I can only discuss the details via email.
tz250w@eikaiwamax.com
As I am typing this at 3am after only four hours sleep the night before I reserve the right to edit this post when I wake up....
However...
TaZ (Max)
- tz250w
- tz250w
Everyone that sent me emails, thank you. Please be patient... I haven't been able to meet with the company contact since I picked up the first prototypes and have been extremely busy every since... I hope to see him on the first and arrive at a final decision. Hopefully, he won't have to be at the circuit that day... He is running a ST600 (Superstock) team in the All Japan Road Race series this year and the third is the opening round. They've had major problems with their ZX6R ('05) during the past few weeks...
TaZ (Max)
sammyboy
- devlin
Re: TRX Rearset Prototypes
Did these rearsets ever get through to production?
- steve speed
some of the last postings are over 3 years old !! does any one know what happened ?
- TonyDevil
they look gorgeous!
if they are still available whats was the cost and when can i have some?
TDM900 2003 - commuting tool
Z750 hardtail - project
- philk
I asked Max about these 6 months ago and got no response.
They are very pretty!!
