Dyno time
Kenny
Dyno time
Post by Kenny » Fri Jul 09, 2010 5:54 pm
I spent a few hours on a dyna pro dyno today at Projex in Cradley Heath nice friendly guy. My bike was runninng very very rich. We went down from 142.5 to 122.5 and we ended up with this curve. The engine has 68,000km on it and uses no oil to speak of. Is this normal, bad or good?
SDN
Re: Dyno time
Post by SDN » Fri Jul 09, 2010 7:16 pm
pretty much normal for a standard TRX especially on a hot day when you can lose a few BHP.
I reckon it's way too easy to get hung up on BHP. My old engineering instructor who was a vintage bike nut - regularly racing Scotts, would allways say when we were pestering him for tuning advice - 'tune your self first'
not that we ever liked the advice, but I did see this old boy beat a GS1000 on an MZ250
Re: Dyno time
Post by Mincehead » Fri Jul 09, 2010 8:13 pm
Tuned MZ `smokers` are pretty rapid old things, seen many of them whip much bigger machinery on the right circuits.
http://www.bmzrc.org.uk/
look at some of these lap times:
http://www.bmzrc.org.uk/Racing/LapRecor ... fault.aspx
I`m biased, I like MZ`s. :wink:
Re: Dyno time
Post by trixynut » Fri Jul 09, 2010 9:33 pm
Pretty much as you'd expect from a standard motor with a set of cans =D>
Nice smooooooooooooth curves too :D
Kenny
Re: Dyno time
Post by Kenny » Sat Jul 10, 2010 11:17 am
trixynut wrote:Pretty much as you'd expect from a standard motor with a set of cans =D>
Thats good news indeed I knew thw motor was torquey but I was shocked to see 50ft/lbs from 3000rpm up to 8000rpm. How much would big bore headers add to this? What size headers are recommemnded for a std engine?
Trixz
Re: Dyno time
Post by Trixz » Sun Jul 11, 2010 9:28 pm
Must agree with Mr. Nut here :lol:
Big bore.... ask KillerWhale e.g., dunno how much it would add, but it sure will ad a bit more to it.
M.V.
Re: Dyno time
Post by M.V. » Mon Jul 12, 2010 4:02 am
Hi Kenny, that chart looks very good!
Are those the jet sizes you settled on for best performance, or did smaller jets go too lean?
Re: Dyno time
Post by cobbadiggabuddyblooo » Mon Jul 12, 2010 9:23 am
:D I had a similar result from my first dyno on a std motor(76000km) with just a set of staintune cans fitted. Who ever set it up had rejetted and it was running way too rich. Once dynoed I gained almost 6hp bringing me back up over 76hp.. It certainly gives you a good starting or reference point once set.. :)
Kenny
Re: Dyno time
Post by Kenny » Mon Jul 12, 2010 9:35 am
What we found was that the main jets didnt have a very large effect on the AFR if we only went down one or 2 sizes. 122.5 was on the lean side so we settles on 132.5 for now. Im planning some airbox mods so I may have to go back up to std 142.5 or higher. The biggest difference now is the bike is so much smoother to ride now and better on fuel I hope.
