Anyone on the list actually done this mod? Am I right in thinking they are a near enough direct fit with just some nominal elongating of the holes to make them fit?
I've found these on eGay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
and it seems a simple cheap mod to actually give me some rearward vision!
Thanks in advance, Corners
SV Thou mirrors
- Corners R Us
- Kenny
Re: SV Thou mirrors
I have these on mine all I had to do was slightly elongate the holes in the top fairing stay. Now I can see behind me and not just my elbows.
- trxify
Re: SV Thou mirrors
cbr mirrors fit aswell!! i've got cbr1000f (94) mirrors on mine, straight bolt on nearly(weirdly i only had to open up one hole a smidge but i'm experienced in that area so all good) , so i would assume cbr600 and vfr750/800 mirrors fit aswell. You CAN see what's behind you. Which is indeed a novelty as the standard items are a bad joke.Corners R Us wrote:Anyone on the list actually done this mod? Am I right in thinking they are a near enough direct fit with just some nominal elongating of the holes to make them fit?
TaDa
It doesn't matter if you're rich or poor as long as you've got money
NWS870R
Re: SV Thou mirrors
Have a look at my wifes bike - i've used SV mirrors on both hers & my bike. Just oval the holes out a couple mm & they bolt straight on, even the footprint profile is near identical.
- Corners R Us
Re: SV Thou mirrors
Thanks for all the responses. Pair of mirrors bought and drill at the ready....be a novelty seeing whats behind me for a change!!
Cheers, Corners
Cheers, Corners
